Question about Wagan Deluxe Ergo Comfort Rest Massage Magnetic Cushion"
<!-- from fixya rte -->Can i get a replacement plug piece - Wagan Deluxe Ergo Comfort Rest Massage Magnetic Cushion"
If I put tap water in 23.7 oz water bottle and leave overnight is ok to add to lucky bamboo just bought , likes filtered water
Posted on Mar 18, 2015
The piece of the chord that you plug into a phone and/or computer fell off of the chord. What do i do
If the mentioned piece is namely the Jack plug of the sound system, the fix for it is the following: you have to stripe back the damaged cord for an inch, and buy a replacement 3.5mm jack plug. You can connect the Jack plug to the cords with a solder, for better audio experience.
Sep 13, 2013 | Harman Kardon SoundSticks II Computer...
How to do a tune up 2004 lincoln navigator
Tune-ups have been gone for most of the last 25 years or more
Your vehicle only has spark plug left from those days
Remove the COP Ignition Coils & replace the plugs
using the champion one piece ones
Go to google & see all the problems with your motor
& the OEM two piece spark plugs
They needed to come out of the motor the day it was sold
brand new,read up on that
Ford 5.4 --- 3 valve motor-- spark plug problems
Mar 02, 2013 | 2004 Lincoln Navigator
Sony e series laptop screen cracked ..Help!!!???
If you can carefully pull the trim piece off that holds your screen on then you can replace the screen. You will need an eye glass repair kit i.e tiny screw drivers. take the model and serial number of the unit and you should be able to buy one on ebay as i did. carefullly remove the trim piece and you should have access to the screen which tiny screws hold it in place. Remove the screws and carefully pull screen out and there should be terminal plugs that go from keyboard to screen. unplug them and remove screen. plug the new screen in and put screws back in. snap the trim piece back around screen and test.
Feb 17, 2013 | Computers & Internet
How to replace spark plugs on a 2000 Oldsmobile Intrigue
On the 3.5 liter v-6, they are in two spots that have plugs. The first three are in the front of the engine. The second three in the back. They are under what is called the"ignition coil cassette". Right in front of the cover that says 3.5 liter is a piece that is about 4-5 inces wide with another piece on top of it about 2-3 inces wide. On the right of this piece you will find some wires plugging into it. The 3.5 liter does not have actual spark plug wires. The wires goto this cassette and this cassette lays on top of the spark plugs. There are seven screws to this cassette, four on top and three on bottom. Once you figure out the front, you will find the back set. However the back are a terror to get to. I had to replace all of the back plugs by feel
Oct 10, 2012 | 2000 Oldsmobile Intrigue
96 Z71 new coil,ignition modual,plugs,wires,cap&rotor,spark from coil,no spark at plugs
Hello: Remove the distributor cap. Check the rotor, see if there is a black spot where the metal piece makes contact with the carbon stick out tha makes contact with the coil. Did you replace that piece when you replaced the coil, it should have come with the new coil? Also did you reinstall the ground strap that was under the coil and went to the stick-out that the black connector plugs into the cap?
Aug 31, 2011 | 1991 Chevrolet C1500
Glow plug error
When was the last time you had your timing belt replaced. Did you do it yourself.
I had mine changed last year and I have known for an entire year that the timing was off slightly. The check engine light WOULD NOT turn off not matter what I did and it kept reading a bad glow plug.
I finally fixed the timing (the camshaft sprocket was off only one tooth) this past Sunday and the check engine light finally turned off all by itself!
Not sure if this fixes your issue, but, it fixed mine.
By the way, if you need the tool kit for fixing your TDI's timing, by it from dieselvw.com. This guy sells a 3 piece kit for $49 where other websites sell a two piece kit for $125 or MORE! I used the kit and it worked flawlessly and the extra piece (the tensioner wrench was handy!).
Apr 05, 2009 | 2002 Volkswagen Jetta TDI
The guitar lead plug has fallen inside.
The safest way to fix this is to take the amp apart to get at the jack. If the jack is a solid black plastic shape, then you should replace the jack completely. Otherwise you should have access from the side of the jack to remove the piece of hte plug that broke off.
Dan
Feb 18, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Ps3 is a piece of sh*t
the ps3 is nothing but a piece of shit
Mar 04, 2008 | Sony Playstation 3 (PS3) Console
Wagan Deluxe Ergo Comfort Rest Massage Magnetic Cushion" Logo
81 people viewed this question
Top Wagan Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Wagan Health and Beauty Expert? Answer questions, earn points and help others
