Question about Engines & Components for Kia Sorento LX 4x4
I have a 2006 kia sorento lx 4x4 with a mitsubishi 3.5 NON interferance engine, the problem at first was the timing belt was shreded due to an idler pulley that had siezed up so after I got into it I
I have a 2006 kia sorento lx 4x4 with a mitsubishi 3.5 NON interferance engine, the problem at first was the timing belt was shreded due to an idler pulley that had siezed up so after I got into it I replaced all the parts that come with a rebiuld kit {timing belt, water pump, idler pulley, adjustment pulley, automatic adjuster and new seals for cams and crank} the only parts I did NOT replace was the crank positioning sensor and the cam sensor. so I reassembled everything and tried to start it up for no result, engine just turns and does NOT fire...my question is 2 part...1 if crank sensor wiring is comprimised would this prevent it from starting? and 2 is there a way to test sensor without tearing everything apart again?
  • 603 Answers
There may not be a problem with your crankshaft sensor unless you cracked the housing or pinched the wire somehow. I think that your problem is with your timing. To check bring number one piston to top dead center on compression stroke and check to see if your valves over that cylinder are closed. I think you will find you timing belt is off maybe a little maybe a lot. Please let me know what happens. GOOD LUCK FRIEND.
Posted on Nov 13, 2014
If timing belt breaks ,will it bend the valves
I looked at interference engine list.
Ford engines
1.8L--1.9 L and 2.0L sohc are not interference engines. I can only go by the database info.
Apr 16, 2016 | 1995 Ford Escort
Where is the waterpump on 2003kia sorento lx ?
Water pump is Timing belt driven. It is below the Camshaft sprocket, in the timing case. If you want to repair/replace it here are the instructions.
COMPONENTS
REMOVAL
  1. Using the drain plug, drain the coolant.
  2. Remove the drive belt and the engine coolant pump pulley.
  3. Remove the timing belt cover, the auto tensioner and idler pulley.
  4. Remove the water outlet fitting, the thermostat case and the water pump fitting.
  5. Remove the engine coolant pump mounting bolts.
  1. Remove the engine coolant pump assembly from the cylinder block.
INSPECTION
  1. Check the engine coolant Water pump for cracks, damage or wear, and replace the pump assembly if necessary.
  2. Check the bearing for damage, abnormal noise and sluggish rotation and replace the pump assembly if necessary.
  3. Check the seal it for leaks and replace the pump assembly if necessary.
INSTALLATION
  1. Clean the gasket surfaces of the engine coolant pump body and the cylinder block.
  1. Install the new engine coolant pump gasket and pump assembly. Tighten the bolts to the specified torque. Tightening torque
Engine coolant pump bolt:
Head mark "7": 17 - 22 Nm(170 - 220 kg.cm, 12 - 16 ft. lbs.)
  1. Install the water pump fitting, the thermostat case and the water outlet fitting.
  2. Install the auto tensioner and timing belt. Adjust the timing belt tension, then install the timing belt cover.
  3. Install the drive belt, coolant pump pulley and then adjust the auto tensioner.
  4. Refill the coolant.
  5. Run the engine and check for leaks.
Courtesy All Data LLC
© 2015 ALLDATA LLC. All rights reserved. Terms and Condit
Mar 15, 2015 | 2003 Kia Sorento
I STILL have my problem...I have a 2006 kia sorento lx 4x4 with a mitsubishi 3.5 that I just replaced timing belt, water pump, idler pulley, tension pulley, tensioner, I also just replaced crank posit
because you have replace engines but I imagine that you have used the crank and cam position sensors on the 3.5 but connected up to the kia ECM there is a possibility that the ecm is not reading those position sensors and not providing timing for the ECM . It will be reading as broken timing belt. I would suggest a scan of the fault codes to determine if there any sensors not reading correctly. You may have to find a speed shop that has CPU programming capabilities to reprogram the ECM/CPU to the different sensors.
Nov 18, 2014 | 2006 Kia Sorento 3.5
I have a 2008 Kia Sorento LX 3.3. where is the adjuster bolt for the idler pulley? Trying to change serpentine belt and idler pulley.
The idler pulley deflects out of the way using a special wrench, the pulley is held against the belt only by a preset spring tension mechanism. You put the wrench on the bolt or in the square drive hole and deflect the pulley away from the belt, it must be manually held there to put the new belt on and then released to tension the new belt.
Feb 10, 2012 | 2008 Kia Sorento 3.3
When to change timing belt in 2006 galant
Timing Belt Replace ment Intervals for 2006 Mitsubishi Galant are as follows:
2.4L 4Cylinder engine: Every 60,000 miles
3.8L V-6 Engine: Every 60,000 miles
Both of these engines are "Interference Engines" which means that if the timing belt breaks, severe engine damage is likely to result.
I personally recommend replacement of the timing belt idler and tensioner pullies as well as the water pump because failure of these components will cause a failure of the timing belt.
Dec 04, 2010 | 2006 Mitsubishi Galant
Does v6 sorento have timing belt
Your 06 Kia, with 3.5L engine V-6, has a timing belt, Kia recommends replacing every 60,000 miles, this is an interference engine, which piston to valve damage will occur due to timing belt failure, hope this was very helpful.
Aug 26, 2010 | 2006 Kia Sorento
How to change a timeing belt on a 2006 Kia Sorento?
Kia engines are interference engines. If the Timing belt is not done exactly right you will destroy your engine. I don't recomend anyone do a timing belt unless you allready know exactly how to do it right.
I have done many , and made a SMALL mistake on my mazda last month and ended up having to rebuild the head and replace valves , guides , and seals.
Apr 14, 2010 | 2006 Kia Sorento
2006 Kia Sorento 4X4, Diesel. Starts right up but runs "rough" (more vibration than normal and valves rattle at low revs) and produces great deal of white smoke until engine heats up (after about 2-3...
i would check all the basics like spark plugs and check for vacuum leaks around the intake manifold.With a can of 2+2 carb cleaner while engine is running --if idle goes up or down that is were your leak is--
check egr too, Lee
Feb 14, 2010 | 2007 Kia Sorento LX 4x4
High revs on start.(is this bad for the engine)
I have heard this a LOT about the Kia Motors. To my knowledge no Motors have Blown from the Action. I do not think that it is Right eathier But, I got the same Explanation when I called for Reference on the Subject.
Jan 13, 2009 | 2007 Kia Sorento LX 4x4
Engines & Components for Kia Sorento LX 4x4 Logo
78 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
