Question about Dryers
Fix my taser in my flash light it 1101 flashlight taser
I cant figure out how to open it up to check the wires
2 Suggested Answers
japace751
  • 227 Answers
SOURCE: Need. To reqiew 1101 policw flaahlight taser
CAN NOT READ YOUR PROBLEM
Posted on Jan 21, 2016
How do I change a spark plug on a Craftsman F 5000 riding lawn mower
open hood, find plug wire and remove it from plug, remove plug, install new one, reinstall wire, close hood. its that simple. if you cant figure that out you should get help from a shop. period. do you own any tools??
Jun 17, 2017 | Craftsman Garden
I have a transom mount 12volt i was fishing the other day and it just quit working come home and checked my voltge that was but doing some testing i found that all the wires going to the actual go to the...
The motor windings are very low resistance so checking for a short is difficult. However, It sounds like a open rather than a short circuit. The switch might be open. Try jumping the switch to see if that works. If not then visually inspect for opens. To go further would require a schematic, disconnecting wires, etc. It would help to have the nameplate information or a copy of the schematic to really help, Send me an email at vze2m6dn@verizon.net. Ed
Mar 16, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Have a2003 buick rendezvous 3400 p0303 changed plugs, wires , coilpack ,then i got it did compression check 140psi figured mechanicly good figured injector replaced that and still same misfire. was...
you might not be getting a injector pulse signal at # 3 cylinder ? easy way to check this is with a noid light, it plugs in to the end of the connector and as crank the engine the light should flash. if it does not flash check wire harness for a open circuit from injector to computer ( e.c.m.) if thats alright possibly e.c.m. bad . if you cant find noid light you can use a digital volt meter. good luck
Feb 19, 2011 | Buick Rendezvous Cars & Trucks
Just replaced my fried multi-switch board for the power windows
original could have fried because the power motor fried or you could have wiring that is melted and electrically open. You need a voltmeter and a schematic of that system and start checking for missing 12vdc.
Apr 24, 2010 | 1994 Pontiac Grand Prix
I cant figure out how to change it the passcode
If you want to change the code for your keypad do this. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My 1978 Chevy Impala loses its charge when I put any load on the car, ie lights, radio ect. I have a new battery and a new alternator on the car, my batter continualy losses it charge and I cant figure out...
most likely wiring around alt or starter any aftermarket radio,amp??? car alarm??? check for open wiring . the alt.can be checked for free at any Autozone.sounds like open wires somewhere or maybe one that is grounding out on the car engine or frame
Oct 04, 2009 | Chevrolet Impala Cars & Trucks
Cant figure out what all the wires go to
Most car stereos have wiring for power, ground, speakers and amps/accessories, if you do not have an amp or fewer speakers you will not use all the wires, look in your manual or look on line for a wiring diagram to see what all the wires go to. Your main wires will be main power (usually Red) Back up power (for memory usually orange or yellow) a ground wire (usually Black) and speaker wires.
Aug 21, 2009 | Kenwood Car Audio & Video
Restoring a 1953 ford truck v8 flathead 239 and cannot get fire to ignition switch, distributor or coil. I have tried everything. All wiring is new. have traced all of the wires. cannot figure it out. i...
you should have battery power going into ign switch. if you do not then your wiring from switch to battery is open somewhere. i cant pull a schematic on this but would assume it is not connecting thru a junction block trace this wire back to its source and find where you are losing power
Jan 29, 2009 | Ford F-100 Cars & Trucks
The left headlight of my xc90 will not work
you have this car posted under binoculars, not cars.
Jun 18, 2008 | Optics
Wiring diagram
Check here for the info you need.
Mar 13, 2008 | Pioneer DEH-P6400 CD Player
Dryers Logo
141 people viewed this question
Top Dryers Experts
