Question about Corel DRAW Graphics Suite X5
Corel DRAW X6 problems
I encounter the following problem when installing Corel DRAW X6, uninstall and upgrade CorelDraw, correction or other updates: with WIN 7 Ultimate x64 - A new window opens small, and can not increase or collapse; - Nothing happens, just press the "Cancel" in this window, you can. All my cdr files doesn't open. - This happens even when turned off virus protection, Windows Firewall, and even when running in safe mode. I can not get access to more CorelDraw, reinstall it, de-install the patch it with an update.
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Posted on Nov 13, 2014
Hey i really need a corel draw x6 serial number and activation code! It would be really helpful
Purchase serial number: DR16R22-948R22S-L6BHRBG-WNGUZM8
Activation Code:6C86-46ED-2D10-0DEF-F2BF
UPLOAD BY MEVIN DOLCE Brother Printer Support
Jan 14, 2014 | CorelDRAW Graphics Suite X4 for PC...
CorelDraw x6 ID: 410003 30 activation code
Please tell me ID: 410003 27 activation code Corel DRAW you can give?
Aug 27, 2013 | CorelDRAW Graphics Suite X4 for PC...
Coreldraw
I have downloaded the latest version x6 corel draw. can u please tell me how to activate it. it was just a trail version. pls help me. i will be thankful to you
Jul 01, 2013 | Corel Computers & Internet
Activation code for Corel draw x6
Need your help... I need activation code for Corel Draw X6, serial number: DR16R22-K4MG9LH-3V6RE29-VB76G6J Thanks in advance. if something else is need it please let me know it.Thanks in advance
May 28, 2013 | CorelDRAW Graphics Suite X4 for PC...
Activation Code for Corel Draw X6
You will have to refer this to Corel for resolution
May 08, 2013 | CorelDRAW Graphics Suite v.X6 - Complete...
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
Corel DRAW Graphics Suite X5 Logo
3,877 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
