Question about Pool & Spa
I think I need to slide one of the weights up but I can't budge it??
Will not lie flat on the pool, most of the time, so I wanted to slide one of the weights up, but i've tried and tried and I can't move it.
  • 3,368 Answers
Great question but what are we talking about?
Posted on Dec 10, 2014
2 Suggested Answers
  • 54 Answers
SOURCE: I have a 20X40 rectangular
The first weight from the cleaning head should be adjusted so the Kreepy sits flat on the floor with the system turned off. Then you can start moving the next weight until it starts climbing the hill to the shallow end. It may take a few times but if you get the weights set correctly it should work.
Posted on Sep 05, 2011
What section do I put pool hose weights
shallow pool, one weight 4" to 12" from the head. as deep as 7', add 1 weight 6' from the head. deeper than 7', add 1 weight 10' from the head. If deeper than 12', add one more weight 12' from the head.
Apr 03, 2014 | Universal Kreepy Krauly In-Ground Pool...
I have a 20X40 rectangular liner pool and my kreepy krauly stays in the deep end of the pool. I think I need to adjust the weights. Where should the weights be placed?
Aug 17, 2011 | Universal Kreepy Krauly In-Ground Pool...
Falls on its side
If these pool cleaners are leaning to one side, it is most likely a problem with your hose. First, make sure that you have the proper hose weights in the proper places. When the cleaner is setting flat on the bottom of the pool, it should be at a 45 degree angle against the pool floor. For this model, you should have two hose weights on the middle of the second hose section, 1 1/2 meters from the cleaner head. You might need to adjust the weights to get proper balance, but the cleaner should not fall on its side if it is in the correct resting position.
May 01, 2011 | Zodiac Pacer Pool Cleaner
Why does my pool cleaner turn upside down? how can i fix it?
Try adjusting your hose weights to see if that corrects the problem. When your cleaner is resting on the bottom of the pool, it should be at 45 degree angle. If it is tilting back toward the hose, try moving the weights closer to the cleaner. If it is tilting forward, try moving the weights away from the cleaner. You might also need to add more hose weight. If the pool cleaner does not have enough weight to hold it down, it will float. You will also want to make sure that you have adequate water flow through the cleaner.
Dec 29, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My kreppy crawly turns side ways and dosent correct its self
With this brand of pool cleaners, that is almost always going to be a problem with your hose balance. Turn your pump off and observe your Kreepy Krauly. The seal should rest flat on the pool surface and the hose and tubes should be at a 45 degree angle. Adjust hose weights (as follows) one inch at a time until you get the proper balance. If you have a deep and shallow end, adjust to the deep end first.
The hose is too light if it raises toward the surface at a greater than 45 degree angle. Move the weights closere to the cleaner (one inch at a time). If the cleaner is closer to the pool floor, move the weights away from the cleaner.
Nov 05, 2010 | Universal Kreepy Krauly In-Ground Pool...
I have a Zodiac Baracuda G3 pool cleaner once the the pump switches off at night the next morning creepy does not sit flat on the bottom of the pool the front side stands up in the the air if you lift the...
It sounds like your house weights need to be adjusted. When the pool cleaner is resting, it should always sit at a 45 degree angle on the bottom of the pool. If it stands up on the front side, try sliding the weight away from the cleaner head. You may need to make several small adjustments to get the balance right, but this is almost surely your problem. Here is a copy of the users manual if you want to read more about hose weights and balance:
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Oct 11, 2010 | Zodiac Baracuda Zippy Pool Cleaner
My kreepy won't move about. Even though the hose is vibrating, it doesn't move about. I just bought new hose so that isn't the problem. I have an 18x36 inground pool. Where should the ring weights be...
With these pool cleaners, there is a simple test you can do to see if your cleaner is weighted correctly. Turn the pump off and observe. The hose balance is correct when the cleaner's seal rests flat on the pool floor and the drive tube makes a 45 degree angle with the floor. Adjust the hose weights one inch at a time as needed until the proper balance is achieved. If the hose is too light, or rises toward the furface at an angle greater than 45 degrees, move the weights closer to the cleaner or move the first two weights closer to each other. If the hose is too heavy, less than 45 degree angle, move the weights away from each other.
Jun 08, 2010 | Universal Kreepy Krauly In-Ground Pool...
Krauly gets tangled in the hose constantly and will not untangle
With these pool cleaners, that is almost always going to be a problem with your hose balance. To determine if your balance is correct, turn off the pump and observe the cleaner. Hose balance is correct if the cleaner's seal rests flat on the pool floor and drive tubes make a 45 degree angle with the floor. If the hose rises toward the surface at an angle greater than 45 degrees, move the weights closer to the cleaner or move the first two weights closer to each other. If the hose sags at less than a 45 degree angle, move the weights away from the Kreepy Krauly or separate the first two weights away from each other.
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
My KK i just bought yesterday, and it wont stay on the bottom of the pool it works for about 10 mins then it starts to float we have moved the weights but that has not helped.We emptied all the water out...
Sometimes additional weighting is necessary. Check with the manufacturer for additional weight rings. the depth of your pool and the buoyancy of the KK is the likely reason. The weights are supposed to be distributed to cancel the bouyancy of the hose.
Jan 05, 2010 | Universal Kreepy Krauly In-Ground Pool...
Can't adjust the weight on Hayward King Ray pool cleaner.
just tug on the weight straight off the hose itll come off and you wont hurt it
May 10, 2009 | Hayward Navigator Pool Cleaner
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
