Question about Microwave Ovens
Can magnetron be replaced without removing microwave?
Manufactured July-2001. Unit is an odd install in a basement with NO CABINET above (it is mounted directly to the ceiling). If I have to remove it to replace MAG, then it's a giant pain in the rear end, so I will just put a new unit if that's the case. I would much rather repair (replace mag) via faceplate only. I CAN SHUT OFF POWER for repair. please advise
  • 51 Answers
Hello
There is no way u can replace mag without removing micro and placing on desk !
There r screws on the side and or behind the outer cover.
The mag maybe ok but the transformer or a common fuse , or rectifier gone bad .
Can to take a picture front and side of the micro location ?
Posted on Nov 12, 2014
  • 619 Answers
SOURCE: Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Posted on Jan 18, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
SOURCE: removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Posted on Aug 31, 2008
SOURCE: kenmore microwave removal
the top vent exhaust grill has two screws facing down-remove these. remove plastic vent. inside you will see a solid wire tringle assy. turn and pull this release.
warning if you have granite counters or tile, place plenty of material under it to stop the impact if oven gets away from you
Posted on Oct 03, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
GE Spacemaker Microwave 5 years old Model JVM1440WH01 The Clock, Fan, Interior and Exterior Surface lights work, but it does not heat the food. Over the stove model,
the magnetron may be faulty on this unit... the magnetron is what heats unit... there is also a thermal limit on this unit mounted behind the control panel and will require removing in order to check... unplug unit and remove two wires attached to limit about the size of a quarter and round in shape..check contuinity and should be closed... if it is then most likely the magnetron has failed... is a replaceable part sorta expensive and requires taking apart the cabinet and removing a few componets to get to the magnetron bolts/screws ...
www.sears.com then hit the parts direct link up at top of the screen enter your model number and will give you a parts diagram check availabilty and price on your part....
sometimes cost verses replacement is worth buying another one.... but can be fixed... most magnetrons have 5 year warranty goes by serial number of unit or installation of unit if your the original owner.... good luck to you
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Antenna
Saibal, microwave repair is a dangerous endeavor if you have not been schooled on them. The antennae you mentioned is part of a larger component, the magnetron. This is a high voltage device (~5000 VAC) and is extremely delicate. Access to it must be from the inside of the cabinet so the unit must be dis-mounted from the wall and placed on a work area. BEFORE PROCEEDING... READ ALL INFORMATION LOCATED HERE!!! http://www.gallawa.com/microtech/index.html THIS WILL COVER THE DANGERS AND SAFETY PROCEDURES. After the unit is on a suitable work area, remove the outer cabinet and set it aside. Now, slow down and visually verify the location of all components... DO NOT TOUCH ANYTHING UNTIL YOU HAVE LOCATED THE HV CAPACITOR!!! After locating the capacitor, follow the instructions listed above to discharge it. Now the magnetron is safe to remove. Remove the wire harness from the magnetron. You will see the 4 fasteners which retain it, remove them and the magnetron will come out. Carefully and gently install the new magnetron and fasten it securely. Reinstall the wire harness to it and rebuild the unit. After installation, test the unit with a cup of water BEFORE reinstalling it. There is a chance that when the magnetron failed, it destroyed the capacitor and/or the HV Diode. If it heats the water, your OK. If not, you'll need the capacitor and diode. I can't stress enough how important it is to follow ALL safety procedures outlined in the link, above! Job time is approx. 2 hours. OK, parts availability... the part number you need is #58001218. I show one available through 1'st Source in Albuquerque, NM. Ph.# (505) 884-0166. List price= $90.98. The gluing technique will NOT work as a repair. The magnetron vibrates at an extremely high frequency and the dome (antennae) will shatter immediately. Please do not perform this repair this way as injury or more damage may be incurred.
Aug 11, 2007 | Maytag MMV1153A Microwave Oven
Won't heat any foods.
you have a problem with your magnetron tube, and when the magnetron tube goes bad, the diode almost always goes out with it. you should be able to order a replacement tube from your manufacturers website, if you cant let me know and ill try to help you more.
here are the steps to replace the magnetron tube, if you want to do it yourself that is. if you have a professional do it, it can be pretty costly.
  1. Unplug Microwave at least few hours before
  2. Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
  3. Remove top cover of Microwave
  4. Make sure to keep screws correctly in a place you remember what goes where
  5. Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
  6. Remove other panels around magnetron part
  7. You need to remove lot of connecting wires, should be careful to note down what goes where
  8. If possible take digital photos to refer back when you put everything back together
  9. You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
  10. Now it should be easy to remove magnetron
  11. Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
  12. Make sure put all wires properly back
  13. Now put transformer back and screw it
  14. Put capacitor panel in place and screw it
  15. This might be a good time to test the Microwave to make sure it works fine now
  16. Now cover the top panels and start to screw everything
  17. Once everything assembled put the Microwave back above range put screws from top
Dec 07, 2010 | Whirlpool MH7140XF Microwave Oven
I have a GE Spacemaker Microwave, Model # JVM165OCB006 Serial # TF900232B Manufactured 10/2003. Runs,turntable,light,timer etc but will not heat. Is it worth fixing?
it is mostly fault of magnetron tube inside Microwave. ge has a 10 year warrenty on this part and they can fix it for you for 200$ OR you can order the part from the web and install it yourself. when the magnetron goes out, the diode almost always goes out too so you'll need another of those too. so if you dont want to replace these then buy a new one if not the the steps to repairing are:
Dec 05, 2010 | GE Microwave Ovens
I have a GE Spacemaker and it is about 9 yrs. old. Sometines it heats; other times it doesn't. I change settings and sometimes that works. Is this something that can be repaired or is this a sign I need...
When the microwave is not heating, that means the magnetron is not working. This is what provides the heat to the microwave. I do believe the magnetron has a 10 year warranty.
If you wish to replace it, here is how:
Sep 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We have a DVM Adora Spacemaker microwave. The unit was manufactured in May 2008 and purchased a few months after. When heating the unit would make a light clunking sound. This began after the first...
The unit was taken into a repair shop. The repairman said the magnetron shorted out and the unit failed. Fortunately, the unit had a 5 yr warrantee on the magnetron (1-yr on everything else). Total out of pocket costs are estimated at $65 to reinstall a new magnetron plus the aggravation of two weeks without a microwave. Those are pretty handy devices to be without!
Nov 14, 2009 | GE Profile Spacemaker Over-the-Range...
How do I install a replacement Frigidaire over the stovetop microwave - professional series, without removing the cabinet above it? I need to know how to best remove the existing microwave.
Remove everything from the inside of the microwave, (such as glass tray). Unplug the microwave, probably in the cabinet above. There are two screws in the cabinet above the microwave, near the front, that supports the front of the microwave. The back is hooked on a mounting plate attached to the wall behind it. An assistant is a good idea though this can be accomplished alone. It is best to move the stove out, if you are going to try alone. Please be carefl there is considerable weight to support here. Support the front of the microwave while the two screws are removed in the cabinet above. Slowly tilt the front of the unit down until you can pull the cord out of the bottom of the cabinet. With the front still tipped down, lift the back from it's support and remove it.
Jul 18, 2009 | Microwave Ovens
Want to remove microwave to install new one.
there are a few ways these can be hung/removed , one is bolting it to the cabinets above it , check for bolts inside the cabinet.
the other way is the bracket in the back of the unit may have a hook or pin around it for a release.
they hide these behind the grill covers on the top or the bottom as well.
let me know how it works out.
Phil
Apr 15, 2009 | GE Spacemaker 1.5 Cu. Ft. Over-the-Range...
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removing Microwave
I just got my Whirlpool MH7100 off the wall. It was a bit of a hassle. I could not find a proper manual online at Whirlpool, but I guess since my unit was manufactured in 1993, who can blame them? Was the Internet even around in 1993?
There were 2 obvious bolts to remove above the microwave, these were found by opening the cabinet above. The next step was the hard one. Even after these were removed, the microwave would not lean forward so that it could be removed from the rear brackets. To get it to lean forward, I had to partially remove and partially break (i think) the vent for the exhaust fan. This revealed what looked like a very large screw with a regular head, one on each side. Once I unscrewed both of these, I was able to lean it forward and get it off the rear brackets.
Nov 25, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
