Question about Canon imagePROGRAF IPF600 - large-format printer - color - ink-jet InkJet
<!-- from fixya rte -->Error hardware 03130031-2F3A - Canon imagePROGRAF IPF600 - large-format printer - color - ink-jet InkJet
  • Kotte Guillaume
    Kotte Guillaume Nov 17, 2014
    After chande ink in printer, screen show error hardware 0313
  • Kotte Guillaume
    After chande ink in printer, screen show error hardware 03130031-2F3A
Error code 6500
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp830 printer is saying error 6500 and i cannot get it to do anything, i have un plugged and re plugged and nothing. what does this error code mean?
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you can ask for replacement
Abhilash
$7 is the charge for the service provided.
Oct 01, 2010 | Canon MP830 All-In-One Printer
Error 6500
The service error 6500 refers to "other hardware error”. This error results from printer hardware failure & nothing much can user do instead of replacing the malfuctioning hardware.
Mar 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
When I reload my F5 5100 I get the following message "hard error: sector 1019072 status 51 error 14: bad format"
Hello my friend, it refers to your hardware components. The error is on your hardware system it causes either the hardware itself where it has a error in the area of SECTOR 1019072 where its status is bad format or its the format of one of your system inside your hardware.
Thanks
Jul 30, 2009 | F5 Networking (f5-big-5110) 24x10/100 Mbps...
Wont read/write hard drive
use Apple Hardware Test to diagnose the error::
1 Disconnect all external devices from your computer except the power adapter.
If you have an Ethernet cable connected, disconnect it.
2 Insert the Mac OS X Install Disc 1 that came with your computer.
3 Restart your computer and hold down the Option key as it starts up. A list of available
startup volumes appears. Click Apple Hardware Test and click the right arrow.
4 When the Apple Hardware Test main screen appears after about 45 seconds, follow the
onscreen instructions.
5 If Apple Hardware Test detects a problem, it displays an error code. Make a note of the
error code before pursuing support options. If Apple Hardware Test does not detect a
hardware failure, the problem may be software related.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 18, 2009 | Apple PowerBook G4 Mac Notebook
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
D3d problem
when i run IGI game they give me an error (no D3D driverswith hardware acceleration found)
whats this i need answer now plz
Aug 04, 2008 | Computers & Internet
Canon imagePROGRAF IPF600 - large-format printer - color - ink-jet InkJet Logo
35 people viewed this question
old marine
old marine
