Question about Kitchen Ranges
<!-- from fixya rte -->How do replace grease filter - Kitchen Ranges
How to replace filter in over the stove Dacor microwave
If it is damaged, replace it. Otherwise a good hot cycle in the dishwasher should get it reasonably clean... http://www.appliancepartspros.com/dacor-grease-filter-239x300-101951-ap4297764.html
May 24, 2014 | Dacor GREASE FILTER 239X300 - 101951
What all is involved in a regular vehicle Service?
Basically you change the oil and filter and possibly the air filter and fuel filter if they haven't been replaced recently. Most ball joints and tie-rod ends and such are sealed on newer vehicles but if they have grease zerks then they will need filled with grease. Also the u-joints may have grease zerks to lubricate.
Mar 05, 2011 | 1995 Jeep Grand Cherokee
How do i reset the grease filter indicator icon on the display on my arietta range hood
From the manual: To reset the grease filter saturation alarm the user must press the "+" key for 5 seconds, after this action the icon "grease filter" is not display [sic], and the hood has the normal display operation.
Feb 19, 2011 | Microwave Ovens
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
GE Microwave oven JVM1440BH01 vent does not draw fumes from the stove top even though motor is running and air is coming out of the top vent.
Your grease filter or charcoal filter may be clogged.
I would refer you first to the owner's manual, then if everything is set up right, you may need to clean the filter (if it's a grease filter) or if it;s a charcoal filter, it will have to be replaced.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 29, 2010 | GE Microwave Ovens
Grease leaking from front end
Check the axle boot. When they rip or crack they will sling grease around.
Oct 29, 2009 | 2000 Chevrolet Blazer
Jenn air s166w down draft range with ill-fitting grease filter when we moved in. I think the range is 20+ years old. The replacement part I ordered is too wide (6 3/4 inch) for the opening of 4.5 inches...
i have had trouble with this filter in the past, it seems they changed the body style years ago and the filter you have is for the new down draft
but your problem is not that hard,
you can buy the proper air filter at you local hardware store and make your own replacements for pennis on the dollar,
one 3.00 filte will get you between 3-9 filters
you want a charcoal filter you can just lay it in under the air grate
Oct 08, 2009 | Kitchen Ranges
Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Jun 29, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Dirty range hood filters
You can purchase grease filters for only a few pounds from many super markets, these can be cut to size to suit your hood. Changing charcoals filters is more expensive but should be done every couple of years depending on your usage.
Mar 18, 2009 | Kitchen Ranges
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
