Greetings. I'm thinking of buying a Technics SE- A 900 power amp but the lights don't work. Does any body know where I can fix and approx how much. Many thanks
  • Audio Player... Master
  • 5,056 Answers
Personally I wouldn't buy it. A power failure could indicate a serious problem. Most amp power failures are caused by power transistor failures. Sometimes these transistors can cost a lot of money if they are not common type. I once had a amp where one transitor would cost £50 to replace, and it need 3 of them!
Posted on Nov 18, 2014
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: My technics se hd 51
please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
Posted on Jul 13, 2008
SOURCE: no cable for technics
I had the same problem with my sua900s pre-amp.
If it's the same cable, you need a (I think 6 pin) mini din cable, male to male. It's sometimes called a PS2 cable (nothing to do with Play Station!). It's the same cable that runs from your mouse into your pc and is readily available for about £5 from online computer retailers. Check the number of pins first though!!
Posted on Feb 18, 2009
technical114
  • 1851 Answers
SOURCE: is there volume adjustments on a technics amp
Technics SE-TX100 is a power amplifier and has no volume controls on it. Uoy can control the volume from the preamplifier tha will give the signal at SE-TX100.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: In case of a problem or clarification, don't hesitate to post me a reply.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 11, 2010
caroldon
  • 17129 Answers
SOURCE: Technics SE-A 2000. Powers up
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the mosfets fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes.
If so replace the outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit.Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Posted on Apr 28, 2011
Testimonial: "thanks for the advice."
What is compatible mixer for technics sl-dq33
Take one with a balaced output and well if you want a nice sound then the allen & heath xone 23 http://www.allen-heath.com/ahproducts/xone-23/ is real nice and well build and they have also the c version with build in sound card, but that unit is a lot more expensive . But when it comes to soundquality, this the one. Numark makes perfect tables, especially the x serie , i have a x-5 for scratching but my denon has the best parts for it\'s price , with real good capacitors, only your choice will be the xone. and costs 300 euro, three times more expensive then the numark. and with build in soundcard 200 euro extra. For less you don\'t buy a lot and don\'t take the reloops, those are very old and upgraded four times. Greetings richard
Dec 29, 2013 | Technics Audio Players & Recorders
Technics su-g50 amp powers up but no sound and no click when powered up
Greetings
Mostly this happens when power output is damaged
or the power supply circuit has a problem
the amplifier has a voltage detection when its over or under voltage it wont let the unit to start normally.
Hope this helps.
Dec 26, 2013 | Technics Audio Players & Recorders
Technics SU-X302 Problems
Greetings
Is there any indicator on or its all off?
anyway i will assume that there is none
1.check power fuse if blown.
2.check power transformer if there is any output voltage
3.check internal fuses
more information will give a better idea.
try these steps and hope this helps.
Dec 25, 2013 | Technics Audio Players & Recorders
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
I HAVE A BSR 3000 EQ, A TECHNICS POWER AMP SE-9021K,AND A TECHNICS SU-9011K PRE AMP HOW DO I HOOK IT ALL UP?
Very easy.
SOURCE > PRE-AMP > EQUALIZER > POWER AMP.
Not sure why you want to do it, though. Your pre-amp already has an abundance of sophisticated tone controls and filters.
If I might venture a guess, you are trying to correct some serious deficit in your speakers or in your source. If you need sophisticated tone controls, filters, AND an equalizer, you need to ask yourself why ... and fix that problem.
Oct 12, 2012 | Audio Players & Recorders
96 900 SE turbo, brake light and tail light failure on SID. go to put car in reverse and car stalls, Note, License plate bulbs are out as well as 1 of the rear fog light bulbs, don't know if that would...
1996 SAAB 900 SE Brakelight Failure SID info
- stalls in reverse etc.
The problem lies with the grounding point in the left rear body cavity on the floor, see the diagram.
Rust eventually destorys the ground and the car will not run in reverse nor do the backup lignts or the rear hatch defroster work amongst other things
Re-attach the grounding wire to an existing welded stud on the side body panel and the problem is solved.
Sep 20, 2010 | 1996 Saab 900
No cable for technics
Feb 08, 2009 | Technics Audio Players & Recorders
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
51 people viewed this question
 Grubhead
Grubhead
