Compatibilty Can you tell me please is Technics SA-GX350 Receiver compatible with Wharfedale Diamond Speakers. I wondering does the Technics Receiver have enough power in watts to drive the Wharfedale 159 speakers? As far as I know, the Receiver is 50 watts per channel and the speakers in terms of power input are between 60watts and 200watts. Any help would be greatly appreciated as your advice may negate the need to purchase a new more powerful amplifier/receiver. Stephen.
    Master:
  • 876 Answers
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Posted on Nov 15, 2014
  • Stephen Murphy
    Stephen Murphy Nov 15, 2014
    Many thanks. Receiver was 100watts per channel BUT unfortunately I wasn't impressed with the Wharfedale speakers like other models. And these are Flagships int their 100s range!
  • 125 Answers
SOURCE: Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Posted on Apr 09, 2008
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
j2easy
  • 152 Answers
SOURCE: Need a manual for Technics Receiver SA-160
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Posted on Dec 11, 2009
  • 34763 Answers
SOURCE: Zone 2 Amplifier Need
Reread the detailed answer provided in response to your earlier post on this issue
Posted on Jun 10, 2013
SOURCE: Technics receiver SA-GX350 Receiver Manual states
its not safe but manageable.if the speaker impedance is too low, the amplifier will tend to overheat and more power is used up in the amplifier than is delivered to the speaker. Too many speakers on a solid state amp can burn up the power output section.
Posted on Oct 26, 2014
How do i hook up my lg smart tv to my technics SA-GX350 stereo reciever
Connect audio outputs of TV to corresponding audio inputs on rear of receiver
Oct 22, 2016 | Technics Audio Players & Recorders
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
Technics receiver SA-GX350 Receiver Manual states to be only used with 8 ohms speakers. I've used 6ohm speakers with this receiver for over 20 years. Please explain is it safe to do so?
Oct 26, 2014 | Audio Players & Recorders
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Jan 01, 2011 | Technics SA-AX910 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Technics Receiver Nonfunctional - Click, then nothing.
I'm not sure what entry will be emailed to you, so I have repeated the "solution" from the other entry below. Please only update one.
Thanks,
Dan
Initial entry:
There could be a number of reasons for this. It woyld help if you could indicate what resistors you changed. The circuit designation should be marked on the PC board. Please post those here and I'll look further and provide some possible solutions.
Thanks,
Dan
Jul 20, 2009 | Technics Audio Players & Recorders
Technics SA-GX350 Nonfunctional - Click, then nothing.
Please update the initial posting and continue the diagnosis there. The initial response is repeated below.
Thanks,
Dan
Initial response:
Thanks,
Dan
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Apr 06, 2009 | Technics SA-AX720 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
89 people viewed this question
 Grubhead
Grubhead
