I noticed that my tv would blink off for a few seconds then come right back on, this happened intermittantly for quite a while, months, until finally it blinked off and has never come back on... i sus
Westinghouse digital VR-3730 tv I noticed that my tv would blink off for a few seconds then come right back on, this happened intermittantly for quite a while, months, until finally it blinked off and has never come back on... i suspect capacitors on the power supply board as I have fixed a simialr problem in the past on a different tv but was wondering if this is a known issue?
    Top Expert:
  • Televison & ... Master
  • 74,858 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 16, 2014
SOURCE: My 2 month old 37" LG HDTV won't turn on...
just resolder capacitor then use a pc fan on iy
good luck
Posted on Jun 03, 2008
ginko
  • 19396 Answers
SOURCE: 26" Insignia LCD TV will not power up. Green Light Blinks 1x
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
  • 4 Answers
SOURCE: westinghouse sk19h210s won't power on. service
I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again.
Just be careful and take notes when you're digging into it. And mark exactly where the card cage is before taking it loose.
Posted on Sep 19, 2009
tvservice306
  • 458 Answers
SOURCE: ln40a530 samsung lcd tv wont turn on
MAY BE PANEL LAMP BAD
Posted on Oct 21, 2009
  • 4234 Answers
SOURCE: I need to determine which part to replace to
The power supply part number is: 272062 and is available for $116.39 from tritronicsinc.com with a core return refund of $30. This means that upon the return of the defective part, you will receive a $30 refund.
Hope this helps,
Dan
Posted on Nov 18, 2009
Testimonial: "At least now I know the correct part, which I did verify. Thanks 4 info. Need to confirm cause, though. Other guy thinks it's the video backlite board"
Toshiba 42HP86 Plasma TV. No picture, but sound is there
the same thing happened to our 42 HP86 red smow at the top than one day now pcture just sound... we took ours to a television repair shop and said we needed a power source wich would cost about $200 and another $200 for the labour so we were looking at a total of $486 plus taxes..... we still dont know what to do when we bought the tv it was $2000 back in 2004.
Jan 16, 2010 | Televison & Video
I cannot change the date on the Royal Time Master TC 100.
Open the cover. Note the three buttons: MODE, SELECT, and SETTING. To set the date, press MODE. The hour will blink. Press SETTING until the correct hour (a.m. or p.m.) is displayed. Press SELECT to actually set the hour shown.
Then the minutes will blink. Press SETTING until the correct minutes are shown. Press SELECT to set the minutes.
Then the seconds will blink. If you want to set them, press the SETTING button to set the seconds at 00 and press SELECT again.
The Year will blink. Press SETTING untill the right year is shown. Then, press SELECT to set the year.
The Month will blink. Press SETTING until you get the proper month. Then press SELECT to set the month.
Finally, day blinks. Press SETTING until the right day is shown and press SELECT to set the day.
That's it. You've reset your time clock. Good luck.
Feb 11, 2009 | The Times ROYAL TC100 TimeMaster Time...
94' Buick-Won't start right away......
Replace your Starter Relay and get the Starter and Solinoid Checked out.
Jan 22, 2009 | 1994 Buick Park Avenue
Proscan PS52682 - Turns on then quickly goes off
sounds like a control pannel problem further trouble shooting
Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
good luck
Dec 06, 2007 | LG DU-37LZ30 37 in. LCD HDTV
My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Nov 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
