Question about Hasbro Furreal Friends Butterscotch Pony
Plastic holder that batteries are held in - Hasbro Furreal Friends Butterscotch Pony
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Could you elaborate? I can't see the question beyond "Plastic holder that batteries are held in"
Posted on Nov 12, 2014
How to replace diesel fuel pump on mercedes benz c220 cdi w 203 2005 ?
Not sure on the diesal pump but if there the same not a gard job the pumps under tge car basically under the dricers side rear seat held in place with a plastic holder remove tge plastic holder 3 or 4 10mm plastic nuts the pump has a wire going to it remove this then there are 2 pipes 1 in from tank 1 out to engine unscrew these and replace
Jan 26, 2018 | Mercedes-Benz C-Class Cars & Trucks
What kind of charger does this Kodak Dashboard CW330 take?
The original battery pack is nothing but 2 AA batteries held together with a plastic holder, you can use regular AA rechargeable batteries and save some money. I had a similar camera with the original battery pack held together with some plastic holder, I simply substituted that battery pack with 2 regular rechargeable common batteries and camera works the same.
Mar 03, 2015 | Kodak Cameras
How do I install two C batteries correctly into my Stinger hand held bug zapper ?
The flat end of the battery (with out the nipple) normally goes to the spring in any battery holder. There is normally a picture of the battery orientation in the plastic molding of the battery space (sometimes hard to see)
Sep 03, 2014 | Cars & Trucks
Door handle does not work
The actuator has came off the hinge or handle.. Remove door panel, and inspect actuator rod. It fits into a small hole at the hinge or handle, or it may have came off the handle end. These are held in place by a very weak plastic holder that dry and break over time. Autoparts store should have the plastic holders.
Dec 06, 2013 | 2009 Volkswagen Golf 5
Install Positive Battery Cable 2000 GMC Sonoma
this cable goes from the battery down to the starter. and i believe it has a another wire on this cable that goes to the rear of the altenator. the wire that goes to the starter, has a holder somewhere along it's route to the starter, it's a plastic lock type holder to keep the cable from getting near any moving object's. I take a small screwdriver to unlock this holder you have to look real close to see how it comes apart. and the cable is held to the starter with a 15mm nut
Sep 16, 2011 | 2000 GMC Sierra
How do I get to the battery of my 2007 Road Star?
On the right side side of the bike there is a compartment with a small hex screw on the bottom left side. Use the larger hex wrench from your tool kit to remove this screw and the cover will pull off. The battery is then held behind a black plastic holder, which you can remove by prying the rubber strap off of the bottom.
Jan 18, 2010 | 2007 Yamaha Road Star
How to change brake lights on my 2007 toyota yaris
on either side of the boot interior, there are what look like air vents. these clip out from the top (with a flat screwdriver) you then unbolt the light unit, pull it out. the bulb holder then unclips easily.
Jul 13, 2009 | 2007 Toyota Yaris
I wish to replace the battery myself, how do I do this?
Polar tells its customers to send watches to them for battery replacement. But the Polar Fitwatch is too old (may have been introduced in 1997?), and they no longer support it. So the only solution is to replace the battery some other way.
For most people I'd say go to a store that sells watches, they'll replace the battery for a fee.
For those who are handy, you can replace it yourself. I did mine yesterday.
The battery is a common type - CR 2032.
You'll need a small screwdriver, philips type, I think. Maybe around 00, or thereabouts. And you need tweezers, preferably with a rubberized grip.
There are four screws holding the back plate. Remove three, and loosen the fourth. Slide the back plate aside.
I unscrewed the screws, then used the tweezers to take them out. They're a bit small for your fingers to get a good grip on them.
The battery is held by a plastic holder that's held by 4 screws. These are (to my eyes) slightly smaller than the ones holding the back plate, so please keep those separate - and keep track of all the screws.
Remove the plastic holder, and make sure you keep track of the spring that's between the holder and the back plate. It'll likely fall out when you turn the holder over.
The holder keeps the battery with a small prong, but it's easy to slide out the battery. Replace the battery, getting the orientation right, making sure you don't touch either side with your bare fingers. This part is easier than it sounds.
Replace the holder, and of course you noted beforehand what the orientation was, so you get it in the same position.
Use the tweezers to drop each screw into its hole, then screw it in.
By this time, the watch will probably start beeping when you tighten one of the screws, because you depress one of the buttons on the front.
Put the spring back in its hole, then slide the backplate back into place, and drop the screws in place with tweezers and tighten one by one.
You should be able to find a manual (which doesn't cover battery replacement procedure) by searching for polar fitwatch manual.
Apr 28, 2009 | Watches
Hasbro Furreal Friends Butterscotch Pony Logo
109 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
