Question about Ovens
<!-- from fixya rte -->How to connect terminal block - Ovens
    Master:
  • 876 Answers
Another extremely vague question - or statement. No Make / Model info at all ...
Posted on Nov 15, 2014
Fisher Paykel OD302 double wall oven. Exhaust fan assembly (vent fan) wiring.
get an electrician in to fix it
the red wire is normally the active (power wire) and the blue is the neutral wire
if you fit the blue to a red terminal then you could be dead, blow the circuit or blow a circuit breaker
be safe call an electrician
Dec 05, 2016 | Fisher and Paykel Ovens
My wires are labeled A1,A2 ,A3 and A4 .how do they connect to the terminal block
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps..
Apr 16, 2011 | Bakers Pride P-44S Oven
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
Oven wont come on
If Your oven wont turn on, then You need to be sure that the problem is power related. Try to test Your device for power, then You replace the power switch of the oven. To test the power of the device. Be absolutely certain the power is turned off before you begin. To do this, check the clock, timer and oven light, and examine the heating elements on all settings. If any of these components operate, you have power. If a wiring problem has short-circuited one leg of the circuit you may have 110 volts but not 220. This means the oven light, clock, and some heating elements may operate on low, but not on high. It also means you have power and could get a jolt. A jolt from 220 volts can be fatal, use caution! Once you are confident the oven has no power it is time to establish if the problem is the house wiring or the oven itself. Check the housebreaker or fuse and then test for power where it enters the oven. If there is a 220-volt wall plug, disconnect the fuse or turn the breaker off, then pull the oven away from the wall and pull the plug. Turn the breaker back on and test the wall outlet. Also check the terminal block, located just inside the back of the unit. This is where the main power cord attaches to the oven circuitry. If your oven is wired directly into the house, the wiring will be connected to the terminal block. Follow the steps above and while the power is off, locate the three-wire terminal block and inspect it for signs of damage, overheating, or melted terminals. Some installations have 4 wires. The 4th wire is a ground for the cabinet. Ensure all wiring is clear and remember not to touch bare wires or terminals. To check the terminals for power, turn the breaker or fuse on briefly and check the terminal block for power across all three legs. Then remove the power at the breaker fuse. If the terminal block is receiving power, then the problem is within the oven and you will need to isolate the problem using the wiring diagram, found on the back of the oven in a plastic pouch, or on the back or inside the oven near the broiler. If the terminal block is not receiving power, your house wiring may be the problem. Should this be the case, you will need to call an electrician.
Hope this information helped You.
Jan 15, 2011 | Thermador Ovens
It has a white wire,red wire,and bare wire but I on have 2 black wires and one bare wire for ground that comes out the wall.I don't know what hooks up with what
Hi and welcome to FixYa, I am Kelly.
What is the model number so I can look up the installation procedures for THIS oven?
Usually for a 3 wire connection it will be connected as follows:
1 WALL black to the left terminal block terminal
The bare copper wire to the center terminal of the terminal block
2nd WALL black to the right terminal of the terminal block
See this picture link:
http://www.ask-the-electrician.com/images/RANGE%203-WIRE_CORD_CONNECTION_250.JPG
If you notice in the picture it shows a black red and white connection.
Red = black for your connetion 115VAC
White = bare wire neutral Ground
Black = 2nd black for your connection 115 VAC
When the power is connected properly and using the house wires as a reference if you are
reading it with a meter you would read EITHER black wire to the bare wire = 115 - 120VAC
Reading Black to Black = 230 - 240 VAC
If you still have questions feel free to respond here and I will gladly help you.
Thanks for choosing FixYa.
Kelly
Dec 02, 2010 | Ovens
The terminal block that the power cord plugs into sparks
The part is called the terminal block and is part number 5304409888
It gets burned due to not being connected tight when the oven was installed or worked on last.
Replace the block and repair any burned wire ends. Make sure connections are tight and you will be good to go
May 07, 2010 | Frigidaire FEB27S5A Electric Single Oven
Terminal Block
terminal was loose started arcing like a welder causing heat to melt the block
Apr 09, 2010 | Ovens
WHERE THE WIRING TERMINAL BLOCK IS
The terminal block is always at the rear of the oven.
There should be a removeable cover, which will expose the terminal block.
It may be screwed on, or a lift up plastic cover, but it will be there.
Jan 28, 2010 | Ovens
Terminal block at back of oven burnt out, is it repairable?
You can get a replacement terminal block from Hotpoint, or you can buy a 30 amp terminal block from B&Q or somewhere like that, and fit in place of the block that is on.
It will be o/k if you do this.
Please rate my solution.
Thanks.
Nov 02, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
