Question about Kaco Blue Planet 1502xi 1-Ph Grid Tied Inverter
What causes a ground-fault in a solar inverter?
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
Apr 14, 2015 | Inverter Electronics - Others
How do i convert my 1.2kw solar inverter on my roof so i can run my home on stored energy ?
Solar panels produce DC voltage.
some solar panels have the inverter integrated into each solar panel.
I would suggest contacting a local solar panel supplier and asking them if they could add a Battery Charging System to the Solar panels you use. An then what sort of inverter to add to the bank of batteries.
An inverter converts DC voltage to AC voltage to use in the grid.
The AC voltages and DC voltages involved have the possiblity to kill if you much around with electricity.
Jan 15, 2015 | Inverter Electronics - Others
Need installation instructions for aerosharp HR-INV-XOI-030 solar inverter
My HR-INV-X01 PV Invertor LCD Display has nothing. No power, run or fault lights however the blue safty switches note ON. What could be the problem?
Jan 07, 2011 | Solar Grid-tie Budget Package: Panels,...
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Nov 25, 2009 | Xantrex Technology Trace Series Inverter /...
Kaco Blue Planet 1502xi 1-Ph Grid Tied Inverter Logo
Top Kaco Electronics - Others Experts
Are you a Kaco Electronics - Other Expert? Answer questions, earn points and help others
