Question about Electrical Supplies
<!-- from fixya rte -->Change the spark plug, where is it ? - Electrical Supplies
  • 58 Answers
The spark plug is on the cylinder head of every gasoline engine on our universe. There are no spar plugs on any diesel fueled engine.
Posted on Nov 26, 2014
Where is the spark plug
Where is the spark plug In the cylinder head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Tips Replace Lawn Mower Spark Plug
How to Change Push Mower Spark Plug
How To Change Spark Plug on John Deere LA 105 Lawn Tractor or Riding Mower
How to change spark plug on craftsman LT1000
Mar 27, 2016 | Garden
Not getting spark
check the coil first with a spark plug tester. then go to the leads at your spark plugs if no spark at the coil change it. .if spark found at the coil but not at the leads at the spark plug. then check the distributor cap and the rotor arm clean the contacts then check the plugs smell them of fuel if that is found change the spark plugs.
Dec 21, 2013 | Cars & Trucks
Change spark plugs on a 2004 buick lesaber
Why you want change spark plugs wire .THIS IS LAST THING TO CHANGE.Change spark plugs I agree.
Apr 01, 2013 | 2004 Buick LeSabre Custom
Engine missing wont fire properly, i think its the spark plugs how do i change them ?
CHANGE SPARK PLUGS.YOU NEED SPARK PLUG 3/8 SOCKET.YOU NEED SHORT AND LONG 3/8 EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER AND A SPARK PLUG GAUGE SET THE SPARK PLUG GAP.NOW CHANGE 1 SPARK PLUG AT A TIME SO YOU MIX THEM UP GET FIRING ORDER MIX UP CAR BACK FIRE WONT CRANK.ALSO CHANGE PLUG WIRES ALSO.
Nov 10, 2010 | 1994 Honda Civic
How do you change the spark plugs?
To change the spark plug on chain saw or any small engine >>
> pull off the spark plug wire
> use a socket wrench (like mechanics use on cars)
> select right size socket (buy at hardware store
> the hardware store might remove the spark plug for you
> rotate spark plug counterclockwise to remove
> identify correct spark plug (buy at hardware store/ home center in lawn and garden section)
> Install new spark plug
> push spark plug wire back onto spark plug
Oct 10, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
How to change plugs on honda odyssey 2005
you will need
8mm
10mm
5/8 spark plug socket
3/8 ratchet
3/8 extension (it could be 4in and longer)
and spark plugs factory plugs are pregap iridium
spark plug torque is 13.0 lb.ft
coil torque 8.7 lbf.ft
spark plug part # NGK 1zfr5k-11
# DENSO pkj16dr-m11
and spark plug anti seize on spark plug thread
what you need to do is remove the plastic cover 8mm socket or 10mm sockets
now remove the spark plug covers and remove the spark plug coils too 10mm head bolt you will need a 5/8 spark plug socket and a 3/8 ratchet and a 3/8's extension too
you need OEM spark plugs they work the best
hope this will help
May 22, 2010 | 2005 Honda Odyssey
How to change spark plugs
for a start leave the battary connected then remove one spark plug lead and plug at a time that way u wont have a problem
Mar 13, 2010 | 2000 Chevrolet Cavalier
I would like to know how to change the spark
FIRST OF ALL YOU HAVE CHANGE SPARK PLUGS WHEN ENGINE IS COOL.IF YOU CHANGE THEM WHILE ENGINE IS HOT YOU COULD DAMAGE THE ALUMINUM HEADS OR CAUSE DISTORTION.TO CHANGE SPARK PLUGS YOU NEED A SPARK PLUG SOCKET.A TORQUE WRENCH.ITS NOT MANDATORY.BUT IT WILL KEEP YOU FROM OVER TIGHTEN SPARK PLUGS.YOU NEED A 3/8 RATCHET AND EXTENSION.YOU ALSO NEED A SPARK PLUG GAP GAUGE.AND SPARK PLUG BOOT PULLER.YOU ALSO NEED SOME ANTI SEIZE COMPOUND.TO PREVENT DAMAGE THREADS WHEN INSTALLING THE SPARK PLUGS.
Oct 13, 2009 | 1999 Ford Expedition
Change spark plugs on 2007 Toyota Camry
In servicing the spark plug . If the owner will be the one to change the spark plug then. the owner should locate the spark plugs . then prepare the equipments that is going to be used to change spark plug .First disconnect the spark plug cable to the spark pug . Then use the equipment to take the spark plug off to the engine. The spark plug should be twisted counter clock wise using the equipment to remove the spark plug.Then replace the spark plug.In returning the spark plug ,using the equipment you have to twist the spark plug clock wise . Then set the distributor shaft turn it according to the proper firing order that will be set to the spark plug if it is 1,3,4,2. Then the distributor shaft mark will be on 1.If 2,3,4,1 then the distributor shaft mark will be on 2. Then connect the spark plug cable , after connecting the owner have to test start the car so that to if it back fires .If it back fires then the owner have to repeat again the setting of the firing order of the spark plug until it will not back fires.If the owner don't have time to do the job in servicing or changing spark plug then the owner have to go to a car mechanic and let them change the spark plug.
Sep 26, 2009 | 2007 Toyota Camry
Electrical Supplies Logo
20 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
