Question about Toys
<!-- from fixya rte -->Plastic holder that batteries come in - Toys
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 99 Answers
What's the question? Not enough information.
Posted on Nov 12, 2014
What kind of charger does this Kodak Dashboard CW330 take?
The original battery pack is nothing but 2 AA batteries held together with a plastic holder, you can use regular AA rechargeable batteries and save some money. I had a similar camera with the original battery pack held together with some plastic holder, I simply substituted that battery pack with 2 regular rechargeable common batteries and camera works the same.
Mar 03, 2015 | Kodak Cameras
Plastic holder that batteries are held in
Could you elaborate? I can't see the question beyond "Plastic holder that batteries are held in"
Nov 12, 2014 | Hasbro Furreal Friends Butterscotch Pony
It appears that my battery for these headphones doesn't hold it's charge....It's hardly been used Battery type.....BP HP550-11 for headphones Serial No MDR RF 840RK
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece on the BP-HP550-11 battery pack (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Dec 03, 2010 | Sony MDR-RF960RK Consumer Headset
I need rechargeaable battery for wireless sony stereo headphones mdr-rf860r
Since many Sony headsets use the BP-HP550-11 battery pack, I assume your battery pack is the same. If not, I assume whatever battery pack your headset came with, it is some type of plastic holder that holds two batteries together. Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Nov 19, 2010 | Sony MDR-RF960RK Consumer Headset
Toshiba Tecra M2-S630 cmos clock battery location
It's under the Keyboard. It is referred to as an RTC battery. (Real Time Clock)
1) ALL power removed from the laptop. AC adapter (Charger) and Battery.
2) It would be in your best interest to buy, and wear an ESD wrist strap.
(Electro Static Discharge)
Connect the alligator clip to a good ground source.
The price of an ESD wrist strap averages from $3 to $12.
Carried in a multitude of stores.
Example of an ESD wrist strap,
http://ultrastatinc.com/ESD_Wrist_Straps.html
[ Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
You may not see it, or feel it.
Your computer will. POOF!
I connect to the metal frame of an empty desktop computer case ]
3) Keyboard Removal:
Laptop closed turn the laptop over. There is 1 Philips screw to remove down in the middle of the Battery Compartment, towards the inside edge. (Battery removed)
Turn the laptop over to it's normal position. Open it.
There is a slim strip of plastic that covers screws that hold the Keyboard in place.
The name of it is Keyboard Holder.
It is right above the Keyboard on the LCD screen side, and below the strip of plastic that contains the Power On button, LED lights, and speaker ports.
(This strip of plastic above is part of a cover, that removes when the LCD Display is removed. It isn't an LED/Switch Cover, per se)
Ease your fingertips in-between the latches that hold the Keyboard Holder in place, and the computer, lift up on the Keyboard Holder.
[To explain:
The Keyboard Holder is a slim strip of plastic. Going along it are plastic protrusions, or tabs.
These tabs are on each side of the Keyboard Holder.
Starting from the Left side there are tabs on each side of the Keyboard holder.
Go towards the Right side approximately 2 inches, and there is another set of tabs.
There are 5 sets of tabs.
You need to ease up on the Keyboard Holder by placing your fingertips under it, in-between two sets of those tabs.
The plastic Keyboard Holder will slightly bend, and come up far enough for your fingertips. Then slide your fingertips towards one set of the tabs, and ease up. This part of the Keyboard Holder will pop up.
Keep going towards the next set of tabs, and keep popping the Keyboard Holder up.
Example: Start from the Left side. Come over about two inches from the Left end, ease up on the Keyboard Holder. Slide your fingertips towards the tab set on the Left. Pop the Keyboard Holder up. (The tabs will release) Now go to the right to the next set of tabs.
Once the Keyboard Holder is removed, there are two Philips head screws to remove, that hold the Keyboard in place.
These are at the ends of where the Keyboard Holder was. One screw on each end.
(You'll see plastic tabs coming from the Keyboard where the screws are)
Screws removed ease up on the Front of the Keyboard.
(Front is towards the LCD screen)
Turn the Keyboard over carefully towards you, lay it down on the Palm Rest Cover, (And Touchpad)
(Front of Keyboard comes up, and over towards you)
There will be a flat ribbon cable attached. You shouldn't have to disconnect it, or fully remove the Keyboard in order to access the RTC (CMOS) battery.
The RTC battery is similar to the normal batteries used in a desktop computer, (CR2032), but is smaller in size, and is enclosed in a plastic 'bag'. (Plastic holder)
There are two wires coming from it which end in a male connector. (White)
The male connector plugs into the motherboard of the laptop.
Use your fingernails to ease the male connector out.
This is a link to the Toshiba Satellite Tecra M2 Series Service Manual (Free)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the line that begins with Tecra.
Go across to M2, and click on it.
This is a 16MB PDF file. Takes time for it to download. You won't see anything happening until the file is almost fully downloaded, then the first page pops up.
(Medium speed DSL connection it took almost 2.5 minutes to download. May have to have a talk with my ISPO, lol!)
For questions about the above, or further questions please state in a comment.
Regards,
joecoolvette
Nov 02, 2010 | Toshiba Tecra M2-S630 Notebook
I need a new battery (BP-HP550-1 1/2.4V 550mAh) for my sony headset. Regular batteries will work (non-rechargeables and rechargeables) but I found that the cradle will not recharge the rechargables only...
Nov 01, 2010 | Sony MDR-RF960RK Consumer Headset
I have searched the web for this battery BP-HP550-11/2.4V (two batteries), to replace the ones in our Sony wireless stereo headphone system model MDR-RF970RK.
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work (be able to be charged using the cradle) in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
Sep 22, 2010 | Sony MDR-RF960RK Consumer Headset
Sony batteries BP-HP550
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 27, 2010 | Sony MDR-RF960RK Consumer Headset
Where can i buy a sony battery bp-hp550 1 1/2 4v
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 11, 2010 | Sony MDR-RF960RK Consumer Headset
My battery pack (plastic holder) is broken. Where
Call Meade at this web site:
http://www.meade.com/support/index.html
Apr 30, 2010 | Meade DS114-EC Telescope
Toys Logo
41 people viewed this question
Top Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
