Question about Panasonic Televison & Video
Panasonic PT-52LCX15 tv, says no channel available
No sound or pic...is there a reset button? or a way to pull codes?
  • Panasonic Master
  • 3,904 Answers
If it is saying no channels available then you are not hooked up the source properly.
Posted on Dec 01, 2014
experttv
  • 203 Answers
SOURCE: Convergence On Panasonic PT-47WX54j
Though i answered this exact question tonight, but maby it didnt post, sorry...heres the instructions.
To enter the service menu follow the directions below:
1) Go into the menu and select cable mode
2) Set sleep timer to 30
3) Exit menu and change chanel to 124
4) press and hold volume down button ON THE FRONT OF THE TV
5) A red "chk" should appear in the top right coner
Once you have the red CHK i think you press action to get the menu up, then chose convergence.
RTUNE- changes colors
MUTE-makes the cursor blink and not blink (when its blinking you can move it from point to point, when it stops blinking you can adjust that point)
"7" - saves the changes you have made
When you are done to exit the service menu follow the directions below:
Press ACTION and POWER buttons together on the FRONT of the set
the tv should the reset itself and turn itself off and back on.
Also if you have a convergence problem and have not repaired the circuit then going into this menu and trying to do adjustments can cause major problems in the dcu so if you have not repaired the circuit DO NOT go into this mode. you must first fix the circuit, and if you dont know how to fix it then you should call a repair man. You can cause major problems in the menu that are not fixable once they have been done.
Let me know if you need more info!
Posted on Sep 25, 2008
800pctechs
  • 39 Answers
SOURCE: tv problem
Replace the color wheel.
Posted on Oct 28, 2008
SD Tech
  • 14553 Answers
SOURCE: Panasonic PT-52LCX15- Have a Blue hue along bottom
This is a 2005 model; it sounds like you have a burnt optical light engine: part number is
TZSC03047 Part is about 800 dollars and requires tech approval from Panasonic to buy. A number of these optical engines use an elaborate system of lens---the heat from the lamp can damage the lens and the color that is damaged separates enough inside to cause the blue streak somewhere on the screen. I hope you have an extended warranty on this set.
I do this here for free so if this has helped you give me a vote here.
Posted on Aug 27, 2009
Testimonial: "Excellent response and explanation, this is what I was leaning towards as I replaced lamp twice. Thank you very much."
  • 3 Answers
SOURCE: My Panasonic PT-52LCX15 Projection TV has NO SOUND
Sound board is gone order a new one.
brcurtis
Posted on Sep 22, 2009
  • 50 Answers
SOURCE: lamp timer
hold the Volume Down button on the TV and the Mute button on the remote for 5 seconds.
Posted on Mar 10, 2010
Green haze on panasonic pt-52lcx15
Your EEPROM is corrupted and needs to be reprogrammed. You need a EEPROM data corection tool. Part# LSUQ0100. It will come with instructions on how to restore your EEPROM data. Good luck.
Apr 19, 2012 | Panasonic PT-52LCX15
Panasonic PT-50LC13 50 blinks 8 times at power button
hi, make sure the lamp is fitted securely and the lamp cover as well you may need to reset the lamp counter hope it helps
regards
shaun
Nov 27, 2011 | Panasonic PT-50LC13 50" Rear Projection...
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Reset parental lock for panasonic pt-53wx53
Hi, try this it works' on most pan. tv`s, ON REMOTE push the power button for at least 7 seconds, video-tek
Feb 11, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Lamp timer
Sep 12, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
