Question about Ovens
How do I stop my oven from clicking, there is no error message. The clicking stops when I am using the oven. We have to go to the electric box and turn the oven off to get some peace.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 817 Answers
Is the gas trying to light? Could be the igniter firing.
Posted on Nov 12, 2014
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Posted on Mar 18, 2009
  • 44 Answers
SOURCE: ''stop'' message on electronic programmer - Whirlpool oven
Hi
all you need to do is set clock as oven is in auto mode
to do this you need to press the middle button a couple of times
hope this helps
Posted on Mar 19, 2009
  • 108 Answers
SOURCE: ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Posted on Nov 11, 2009
iwillfixforu
  • 619 Answers
SOURCE: error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Posted on Mar 05, 2010
F43 error on Frigidaire Wall Ovn?
The code F43 means - The cooling fan speed, as read by the tachometer input of the EOC-display board, is abnormally too slow. when the cooker is on can you feel the fan is on through the upper vent? If not then the fan is the problem if you can then the fan sensor is the problem!
Oct 21, 2014 | Frigidaire PLEB30T8A Electric Double Oven
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
We just plugged in our oven and it has E005 Communication error popping on the screen. Any ideas?
1. Turn the clock selector knob to OFF
2. Tweak the oven control by turning the clock selector knob slightly to the left (counter clockwise).
This may stop the popping message.
Thanks
May 31, 2010 | Bosch HBN5650UC Electric Double Oven
It stopped running, shows door for message. no light when the door is open.
there is a fuse that causes this. check it. if door error apears for the micro
Feb 07, 2010 | Whirlpool GMC275PD Electric Double Oven
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
