Question about Concur Mobile
I scroll to the date needed and then it rolls back to another date that was there when I launched the date change window
Steps to return advent roma 3001 to factory settings
  1. Turn on the computer and keep tapping F8 until the advanced options menu is displayed
  2. Use the up/down arrow keys on the keyboard to highlight Repair Your Computer and press enter to select it
  3. Select the language you wish to install (normally English is the only option)
  4. Once you have chosen your language you will be presented with the available recovery options
    • Microsoft Repair Environment - after choosing the UK keyboard layout you will be asked to choose the Operating System you wish to repair. If Windows Vista is not listed then you cannot repair the OS without doing the full recovery. After choosing Vista the Microsoft Vista startup repair tool will run and attempt to repair any startup problems you are experiencing
    • Reinstall Windows - gives you the options available to reinstall Vista
    • Advanced Options - this launches the diagnostic centre allowing you to run chkdsk, launch notepad or bring up a command prompt
    • Exit & restart computer - Exits withut running the recovery process
  5. To continue with the recovery program you need to choose Reinstall Windows
  6. On the next screen you have the ability to launch Vista System Restore and roll back to a date when Vista was last working ok or to run the Full Destructive Recovery. To continue with the recovery program you need to choose Start Full Destructive Recovery
May 07, 2012 | Computers & Internet
Hello i need driver printer panasonic kx-flb802 for win 7 pelease send me or help me tank
What region are you in? Panasonic has drivers for the KX-FLB80x series for Windows 7 here: http://panasonic.net/pcc/support/fax/world.htm . Just click on your region and then scroll down to the correct series. Use the drop-down menu to select your model. At the next page, scroll down to the Download link.
Microsoft has drivers that will run the KS-FLB801 in the Windows 7 OS. The entire unit should work but you will not be able to launch a scan from the all-in-one. (You could launch Windows Fax and Scan to launch a scan.)
Apr 17, 2011 | Panasonic Office Equipment & Supplies
My windows vista home premium is malfunctioning, changed desktop and windows appearance and can't connect to internet. can anyone help me?..muc appreciated.
I would do a restore to when it was working. click on start, all programs, accessories, system tools and choose restore.what ever software was installed after restore date will be removed and you need to reinstall. Hope this helps.
Mar 12, 2011 | Microsoft Windows Vista Home Premium with...
I keep getting a message internet explorer has stopped working
I have seen this issue several time and have owned the same laptop. This is how i fixed the issue that you are having. I disabled the User account controls. Im not sure what operating system you are using i will show you how to turn of UAC on both windows vista and windows 7
WINDOWS VISTA
  1. Launch MSCONFIG by the Run menu or search.
  2. Click on the Tools tab. Scroll down till you find "Disable UAC" . Click on that line.
  3. Press the Launch button A CMD window will open. When the command is done, you can close the window.
  4. Close MSCONFIG. You need to reboot the computer for changes to apply.
  5. You can re-enable UAC by selecting the "Enable UAC" line and then clicking on the Launch button.
    WINDOWS 7
    Go to User Account Control Settings.
    Type in UAC, or go to the System and Security applet. Click on the "Change User Account Control Settings" link.714e9df.pngTo turn off UAC, move the slider to the Never notify position, and then click OK. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.865b1d3.pngTo turn UAC back on, move the slider to choose when you want to be notified, and then click OK. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    You will need to restart your computer for UAC to be turned off.
    This should help cure your problem. Hope this helps you.
Jun 23, 2010 | HP Pavilion dv6000z Notebook
TO RUN JAVA HOW TO CONFIGURE INTERNET CONNECTION
if you use IE you make tips:
1. Launch your Internet Explorer browser.
2. Click the "Tools" button on the top menu, then scroll down and click "Internet Options."
3. Click the "Security" tab and click "Custom Level." Scroll down and click "Enable" under "Scripting of Java Applets."
4. Click "OK" to save the changes and "OK" again to close the Internet Options window.
If you use Mozilla Firefox :
1. Launch your Mozilla Firefox web browser and click the "Tools" button.
2. Scroll down the Tools menu and click "Options." Click the "Content" tab and place a check on "Enable JavaScript" check-box.
3. Click "OK" to save the changes and close the "Options" window.
if you use Opera :
1. Launch your Opera web browser and click the "Tools" button.
Step 2Scroll down and click "Preferences." Click the "Content" button on the "Advanced" tab and click "Enable JavaScript."
3.Click "OK" to save the changes. Click the "Back" button on the web browser to return to the previous page and click "Reload" to run the JavaScript.good luck
Apr 27, 2010 | Sun Java Desktop System
Hi,my windows7 wmp12 is corrupted and won't open and play videos at all i want to know is it possible to either roll back orf install wmp11 in its place or install an uncorrupted version of wmp12
I'm sorry we got disconnected. yes you can roll back to windows media player eleven. Go to control panel and select and remove programs. when the list comes up scroll down to windows media player 12. Click on remove and it should tell you that it will roll back to the previous version after it is uninstalled. Now, if you recently installed version twelve, you can try something else first. Click on start them programs and select accessories and scroll down to system tools and then select restore. when it opens, select to restore to an earlier time and then when the calendar comes up, select the date you installed version twelve of windows media player, then on the right hand side you will see where your windows media player twelve was installed . Left click on that and they should tell you that it will restore the computer to the time before you installed windows media player twelve . your computer automatically set a restore point when you installed windows media player version twelve. I suggest using the restore option first.
Apr 18, 2010 | Computers & Internet
When i switch my asus G1 laptop on it brings up a webpage giving me two options 1) launch startup repair 2) start windows normally the problem is that whatever option i press it comes back onto the same...
Try booting into SAFE MODE by pressing F8 after you turn on computer and before Windows logo appears. If you are able to start Windows in safe mode, you may be able to ROLL BACK your system to an earlier date. In the START menu search box, type RESTORE. This should bring up the SYSTEM RESTORE menu. Choose the RECOMMENDED RESTORE option first and see if that fixes the problem. If not, go back and select CHOOSE DIFFERENT RESTORE POINT and select an earlier date.
Jun 17, 2009 | ASUS G1 Notebook
Why does my icon have a shield in front of it and how do i take it off
In Windows Vista, all icons that have the shield mean that you need to have administrative rights to open that program.
To remove the icon,
  1. Launch MSCONFIG from the Run menu("Start" button + "R"
  1. Press the Launch button.
  2. A CMD window will open. When the command is done, you can close the window.
  3. Close MSCONFIG. You need to reboot the computer for changes to apply.
Aug 07, 2008 | Gateway Computers & Internet
Roll back date
upon booting up press F2 of DELETE to go to bios set up and there you can change the time/date settings. or you when you are on the windows destktop already, on the system tray (lower right corner) you have there your system time, double clck it to adjust the date/time.
Dec 05, 2007 | Computers & Internet
Concur Mobile Logo
699 people viewed this question
Top Concur Apps Experts
Erin Wood
Erin Wood
Are you a Concur App Expert? Answer questions, earn points and help others
