Question about Hardware & Accessories
Culligan Mark 100 Aqua Sensor DIP Switch Settings and Programming: Where can I get complete Manual?
The service tech recently repaired a valve and told me the Aqua Sensor DIP Switch was off and that the unit was simply regenerating every 3 days, needed or not. He flipped one of the DIP Switches and now STATUS typically shows 'LAST 8', my interpretation that means it was 8 days since the last time REGEN ran automatically. On the next [9th] day, the STATUS reverts back to 'LAST 0' and I assume the cycle ran at 2AM last night. Then the cycle repeats over the next 8 days. The manuals I have seem to say the DIP Switch #6 simply controls whether the REGEN runs IMMEDIATELY or WAITS until time set [currently 2AM]. There are some other discrepancies between the manuals and actual display screens on my unit. For example, Owner's Guide Cat. No. 01882220, page 7, states that after pressing STATUS 4 times, '3 10'' appears, but the setting is not used. My display shows '3 08' and printed on the front panel of the Control Unit it states that step '3' is for setting Salt Pounds. Step '4' in the manual says is for Salt Dosage while my front panel says 4 is for Backwash Min. Which instruction is correct? Where can I get complete info about programming for Aqua Sensor model, all DIP Switch settings?
Basti
  • 1447 Answers
SOURCE: Time Signature
Hi
What options do you actually have on the gadget? keep us posted...
Posted on Nov 29, 2008
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
  • 221 Answers
SOURCE: Panasonic AG-DV2000P internal settings
Section 5 (electrical adjustments) of the service manual covers the settings of DIP switch S-4. It is used to calibrate the supply and takeup photo sensors.
Posted on May 22, 2009
SOURCE: Utilitech model 0141224 wall switch
As luck would have it I'm 60, and learned how to program your 0141224 wall switch timer.
You can see instructions with big print and pictures on following page.
Press CTRL key on keyboard and use scroll wheel on mouse to make web print bigger.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Add a comment any time.
You have wired your timer correctly and the lights turn on when you push on-off button.
If lights do not turn on, we need to review the wiring.
Your timer looks like photo below.
I'm going to parrot back the manual with some extra words.
To start, press the reset button and clear any programming
Programing overview:
Each program has ON time ... and OFF time
So you set program1 ON and then set program1 OFF
When you set program1 ON, you choose the Day, hour and minute you want program1 to turn ON.
And then you set program1 OFF, and choose Day, hour and minute for program1 to turn OFF.
Your ON-OFF times for program1 should be on same days.
For example program1 ON for all-days-of-the-week, but program1 OFF is for TU Tuesday, then timer will not work.
IN this case, program1 OFF should also be set for all-days-of-the-week.
Let's start.
Setting the clock:
Press and hold CLOCK button
Keep holding CLOCK button and press DAY button until display shows current day (MO TU WE TH FR SA SU)
Press Hour button until current hour with am pm displays
Press MIN button until current minute displays.
Release clock button and current day and time show on display
At no other part of instructions do you press and hold one button while pressing other button.
Setting programs:
Press PROG button until "1" and 'ON' show on display
This is program1 ON
Press DAY button to choose which days for program1 ON.
You can choose: all-days-of-the-week and MO TU WE TH FR SA SU show on display
Choose individual days and MO or TU etc shows in display
Choose weekdays MO TU WED TH FR
Weekends SA SU show in display
Next step
Press HOUR button to select hour for program1 ON
Press MIN to select minute for program1 ON
Now program1 ON is ready, next, you will set program1 OFF
Press PROG button until "1" and 'OFF' shows on display
This is program1 OFF
Press DAY button to choose which days for program1 OFF.
( Remember, you want same days for ON and OFF)
Press HOUR button to select hour for program1 OFF
Press MIN to select minute for program1 OFF
Now program1 ON and OFF are ready, next, you will set program2 ON by repeating same steps above.
You can set up to 7 programs.
If you don't want to set program2, or any more programs, that's fine.
To exit programming and save your program, press CLOCK.
Now current time shows in display.
Final step: set MODE
Press MODE button until AUTO shows in display. You want AUTO for programming to operate lights. That's it, timer is ready.
If you're going on vacation, press MODE button until RDM shows in display, and then timer turns lights on-off at random
Copy and save these instructions to your computer so you have them next year.
Posted on Dec 05, 2010
  • 20 Answers
SOURCE: Can't find my instruction manual
Hi
Please copy and paste.
Regards
http://waterheatertimer.org/pdf/GE-15042-15079-15089.pdf
Posted on Jan 30, 2011
Culligan mark 100 fixed problem I just need to know how to reset the CS code without calling them out.
Just unplug it for several minutes. You will need to reset the programming, hardness, time of day.
RJ
Feb 12, 2011 | Culligan Sediment Water Filter Heavy Duty
Where can I get a manual for Culligan Aqua Cleer?
I found the manual for an Aqua Clear AC15 at the following web site. Go to the below web site and locate the filters for your system. There will be a link to the manual in a .pdf format.
http://www.freshwatersystems.com/s-69-culligan-water-filters.aspx
May 15, 2010 | Culligan Under Sink Water Filter
Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Mar 05, 2010 | Culligan Sediment Water Filter
Regeneration is nightly as oppsoed to the prrprogrammed 14 days
"DAYS00" indicates it is set to run every day. You may have lost power and it reset to factory settings. If the Gold series softener you have is the Aqua Sensor model (this is a probe in the resin tank that senses a change in the water chemistry and sends a signal to regenerate) the probe can get coated with iron and will either send NO signal or a Constant signal which will make it regen every night.
Usually a Gold series softener is either set up as metered or aqua sensor. There is an option for an override (such as 14 days) or it can be set up as a time clock model. Unplug the softener for 2 minutes and plug back in, re-program the controls to "DAY14". Make sure what the system is suppose to be set up as, Meter, AS, Time Clock.
Here is a link to Culligan for the Gold manual.
http://www.culligan.com/en/service-and-maintenance/customer-support/owners-guide/
RJ
Jan 26, 2010 | Culligan Sediment Water Filter
I need a culligan n8 custom water conditioner manual
The Culligan N8 Custom and Estate 2 water softener systems are basically the same system. Here are a couple links for N8 manual to reset timer and Est 2 manual for other settings on systems that have "DIP" switches to set gallons settings.
http://www.culliganprowater.com/timer-reset.aspx
http://www.culliganwater.com/residential/resources/pdfs/reference/household_and_commercial_circuit_boards.pdf
RJ
Dec 27, 2009 | Culligan Sediment Water Filter
Mark 100 has a
I removed the control panel and saw that it had a series of dip switches. All these dip switches were all positioned to the same side, this is the way it was installed.
I reset it by flipping all dip switches to the opposite side, then unplugged it for 10 seconds and plugged it back in. The LED the. Displayed something other than the "CS" code. With it still powered, I reset the dip switches to original setting and unplugged again for 10 seconds. When I plugged it back in, I was able to reprogram. I'm sit sure if this is how a service tech would reset the control, but it worked for me and my mark 100 has been running fine since. Good Luck
Oct 20, 2009 | Culligan Sediment Water Filter Heavy Duty
To much salt in the water
The final rinse setting may have moved, which will coincide with the salt/brine draw rate...the Culligan units have a funny way of doing exactly that, which, by the way, can generate a lot of revenue for them, if your on a salt route for them to deliver it to you!....I would look up a qualified and TRUSTWORTHY!!! Culligan repair tech, or a service manual to reset this final rinse.
Mar 26, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
My (mark 100 automatic) water conditioner was unpluged for a couple of weeks. Since pluging it back in, it has regenerated every night for the last 10. The salt container is half full and shut off valve is...
If this is an Aquasensor model. The probe is sending a signal to regenerate. It needs to be pulled and cleaned. You would need to call culligan for this repair.
RJ
Mar 09, 2009 | Culligan Sediment Water Filter Heavy Duty
Hardware & Accessories Logo
78 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
