Question about Watches
How do I turn off the daily alarm on a MDC74567W
How do I turn off the beep chime signal on casio f91w?
In a few words, here is how:
1 - Push button C to get to the ALARM mode
2 - Push button A to cycle through the options:
First, you will get daily alarm activated only,
then, only hourly beep signal,
then both daily and hourly signal chime
and finally both hourly signal and daily alarm turned off
3 - Push button C to return to the Time Mode
I try to make it short and straight to the point,
I hope you find it helpful!
Phil
Sep 28, 2017 | Casio Watches
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
My husband bought a watch at Walmart - MDC74567W A126 - he threw out the information and it had no names attached that we could find. The alarm goes off every day and we cannot figure out how to turn
Take it to the Walmart store and ask the associate ate the counter to explain to you how to turn off the alarm. Or ask to see the manual.
Feb 16, 2014 | Watches
Timex expedition wr100m alarm
TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
May 04, 2012 | Timex Expedition Watches
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
Seiko chronological alarm watch
I looked at the Seiko web site and found only one of the listed watches was described as a "chronometer" and that one did not have a daily alarm.
To review the instructions, go to "seiko.com", then "support" and click on "instruction booklets".
There is a diagram showing where the information is that should be entered to give the instructions you need.
Alternatively, below the diagram is a list of watches which you may be able to find your watch .
Feb 16, 2010 | Watches
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
Casio Illuminator
I used the online CASIO web site to locate the appropriate manual and followed directions. Use the bottom left (C) button of the watch to keep pressing between the various modes until I was in the ALARM Mode. Then PRESS the upper right (B) button to toggle the DAILY ALARM and HOURLY CHIME to "OFF", "DAILY", "HOURLY" and "BOTH" on/off.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1950.pdf
http://support.casio.com/manual.php?rgn=1&cid=002
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Watches Logo
35 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
