Question about Sony Televison & Video
I have a Sony KDL-40VL160. I turned it on and the picture looks like pastel colors around all the images. Everything else works fine. I tested a DVD player in an auxiliary input and it does the same
I have a Sony KDL-40VL160. I turned it on and the picture looks like pastel colors around all the images. Everything else works fine. I tested a DVD player in an auxiliary input and it does the same thing. What can I do to fix this problem?
    Champion:
  • 209 Answers
You cannot fix the problem; having the same problem occur with both TV channel programming and using a DVD player means the TV has defect.
Posted on Nov 25, 2014
tvtek
  • 1284 Answers
SOURCE: no picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Posted on Dec 06, 2007
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: Sony Bravia 32'' picture problem - Sony KDL-32ML130
I am having same problem, started today, didnt find any solution to this question on forums :(
Posted on Nov 22, 2009
  • 1044 Answers
SOURCE: sony bravia kdl- 4052510 picture but no sound from
1 Press volume +/- or Mute 2 If it does not work then check if the 'speaker' is set to 'TV speaker' from the "AV set up" menu in "Settings" 3 Press Menu and select Settings. Go up/down and select Set Up icon.Press enter 4 In AV Set up go to speaker and turn on the TV Speaker. This should solve your problem
Posted on Nov 25, 2009
What has gone wrong with the image on my tv?
The T con board is responsible for what you see and is responsible for bad, distorted images.
Oct 20, 2015 | Sony BRAVIA KDL-40BX420 40" LCD TV
Blur-multi color screen on my Sony Energy Star KDL-40VL160. Can that be fixed?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 13, 2015 | Sony Televison & Video
37 inch sony bravia color problem
try to play first dvd on you tv on test if the tv has a problem or on just on you digital/analog antenna..
If the problem is still there when you play dvd the possible prob is T-con board..
hope it helps..please rate..
Apr 27, 2012 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Original installation color flared up around edges and outlines
what she tried to sell her was and HDMI cable for hi def signal between box and tv. now with what your describing sounds like panel solarization. if you can send me a pic i could better verify your problem. sent pic to support@cats-inc.us
Apr 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
HDMI-connection from my computer stoped working
HDMI is a very buggy system, espicially with connecting computers. First off I would check the video output settings of your computer to ensure that HDMI is still active and that it is enabled for mirror monitor or double monitor.
First things first unplug and re-plug at every point. Power cycle the TV and the computer. If that doesnt work then remove the cable, power cycle both devices then re-plug...then move onto the next step.
If you are running windows XP or Vista, right click on the desktop, select "personalize" or "properties" then look at the display settings. There you can adjust the resolution, HDMI has some bandwidth issues with long cables and cheap cables. Try dropping the resolution of the HDMI output if you can't get a stable image.
If that doesn't help you may have to go into the settings of the graphics card, commonly refered to as "Advanced Settings" on XP.
If it still doesn't help get another HDMI source and test the TV, then get another display and test the computer.
Cheers,
Jan 06, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
The lower half of the tv goes black/also pastel colors
yes humidity has been known to make the panel seperate. I live in south tx and work for sony, alot of panels that show that prob is usually the panel seperating. wouldnt recomend to fix to costly around 85% the cost of when you bought it.
Jul 03, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Apr 08, 2009 | Televison & Video
DVDs underwater
go into advanced video options and turn off the "motion enhancement" for the appropriate input. this usually fixes it
Dec 27, 2008 | Sony BRAVIA KDL-46V3000 Television
Ghost Images - Pastel colored images
There are 3-4 issues in here,one of them might be a bad convertion part in there. It is not worth your time and money to guess the issue,if it is under warranty,you should take it back.If not,repair tech. would be the way to go!
solutiondoct
Nov 07, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
