My board is HP infineon b motherboard . when I start my machine that not turn on. power supply is ok. mother board LED also on. how can I find the problem?
    New Friend:
  • 19 Answers
Make sure you have your fans and CPU in, with the proper amount of thermal compound. Also check to make sure that your power supply voltage is at the correct requirement/recommended for all your conponents.
Posted on Nov 12, 2014
  • Alex Fanning Nov 12, 2014
    If your machine is beeping make sure to look up the beep codes.
The Fizz
  • 11 Answers
SOURCE: can't start bios
If its not a brand new motherboard, id un-plug it, pull out the small battery and switch the reset jumper to reset it. If that doesnt work, check to make sure its not infact a graphics card problem.
Posted on Jul 06, 2006
SOURCE: motherboard
looking for the user manual for a matsonic ms8137c+
Posted on Jan 16, 2008
map9966
  • 2351 Answers
SOURCE: motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Posted on Jun 02, 2008
SOURCE: T3624 E MACHINE MOTHER BOARD DIAGRAM
my motherboard can't support of any operating system plz give me
the solution of this prob... (navedaf@hotmail.com)
Posted on Nov 16, 2009
swoop611
  • 488 Answers
SOURCE: Gateway T2838 with Intel 4000812 motherboard
Check ALL your USB ports.. If any of the USB ports have shorted contacts or if the 5v rails are shorted to ground, the power supply WILL NOT switch on.. Also, if any of the items connected to the board have a supply rail grounded, again the board will not allow boot up. Unplug everything from the board and the drive power connectors too, except the power connector to the board and the front panel switches and try to switch on, if it still will not boot, check and recheck the USB ports and all power connectors, if it does, switch off and plug another item in, then switch on again. When you get to the item which prevents the board from switching on, thats where your problem lies. Dont forget, plug things back in one at a time, including the power plugs to the drives and try and power up between each item, and dont forget to power down after each item has been checked..
Posted on Mar 14, 2010
Where can I download a user manual for a Infineon-B 620887-001 Mother Board
Is your motherboard actually Windows 7 Compatible? It looks as if you have an ARM processor, if this is the case you will not be able to install Windows (7 or otherwise)
Apr 16, 2012 | Infineon Computers & Internet
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the...
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
May 28, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
The Wires goes on the motherboard, check your motherboard manual for reference
Mar 17, 2009 | E-Machines eMachines T3830 PC Desktop
About motherboard intel 845 GL/GE
Try another power supply. The motherboard LED is telling you the board is in standby mode. Once you power up & LED goes out it's telling you there is a possible power supply problem.
Mike
Jul 14, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Motherboard
do u have pw switch on right pins power p start with red on that oen go over one to conect the black try both ways never up down on pins tho side to side only ok
Jan 25, 2008 | Intel Desktop Board D845WN Motherboard
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
PC not booting
the mother board can have a short and the green light is on, replace the motherboard. when the power box goes bad, most of the time it shorts the mother board out, this has happened to me a few times. Farren
Dec 25, 2007 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Computers & Internet Logo
225 people viewed this question
David Payne
David Payne
