Line on copy
After make master single line on copy copmlete secanner service no problum salve what is problum secanner or thermal head problum
    New Friend:
  • 38 Answers
1) clean scanner's glass
2) check drum unit or print heads
Posted on Nov 12, 2014
Mitsubishi p93 thermal printer streeking
Thermal heads show faults in two ways.
if a single line through print and you can see some colour in the print is is dust on head. Clean with isoprop alcohol and a lint free swab.
if it is a white line with no colour then its most prob a thiristor blown on the head, the white line will soon expand as other thiristors next the the faild one will soon also fail. A head replacement would be required. Is the head set at the correct voltage, replacement heads come with a test sheet and a value to adjust the head voltage too.
Feb 04, 2014 | Mitsubishi P-93W Printer
Risograph lines
lines could be caused by a bad mirror or scanner led light. or the thermal head that draws on your master. try to open your scanner table and make a master while it is open. check the lights if they are all complete. then check the mirror if there are chip offs on its mirror coating. if the led light and mirrors are in pristine condition then check the thermal head. try to clean it with a dump cotton cloth.. let it dry for a few minutes then try to make a master again.. hope to be of help.
Oct 17, 2013 | Riso RZ220 Duplicator
Sony CCP1300 Cassette Duplicator delayed start on B side in A+B recording.
The delay allows for the leader to pass the record head until modulation (sound) is detected. This is a normal design feature
Jun 18, 2012 | Sony CCP1300 Monaural 1-to-3 16x Master...
What causes error 12 on a gestetner 6123 duplicator
6123 gestetner digital copy printer no salve problum single line on copy. cleane complete scanner and thermalhead,
May 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
Master jamming on SD430 Standard duplicator. Wrapping masters around thermal head roller.
clean thermal head roller with damp cloth or with isoprophil alcohol and dry it with dry cloth to remove static on the master and thermal head roller.
Jan 14, 2010 | Office Equipment & Supplies
Gestetner 5308bt copy printer error after switching on E-01 call service - How can I fix it I am on a ship at present
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Nov 13, 2009 | Gestetner Office Equipment & Supplies
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
Feb 15, 2008 | Brother IntelliFAX 885MC Plain Paper...
jasbo
jasbo
