It has been getting harder and harder to open and close. I tried to open this morning and the side bar has snapped
Hi Vikki
If you're in the UK please visit our FB page to discuss.
If you're in any other country please visit www.quinny.com and select which country you're in, then go to "Contact Us" tab for your enquiry to go through to the customer care team who can assist.
Dorel UK Customer Service
SOURCE: snapped foot rest - quinny buzz
These will let you know the closest; website: http://www.quinny.com/ Tel: 01842 763281 email: [email protected] Hope this helps :)
SOURCE: quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
SOURCE: how do you close quinny buzz
you need to stand at the front of the pushchair, push in the left grey button and then push the right one down and towards you all at the same time!! whilst doing this push the frame down towards the front wheel! when i first got mine had real problems figuring it out once you do its easy!! remember to hook on the safety catch though cause one touch of the handle and it pops open. i did read that in cold weather it can be a little stiff. not sure on the car seat though as didnt have one! sorry
SOURCE: how to open and close quinny buzz pushchairs
If you lock the front wheel and lower the handle bar to the lowest postition first, this will make the chassis as small as it can be. Remove the seat/car seat or carry cot if this is on the chassis.
Then, stand in front of the chassis, with the front wheel between your legs.
Push down the grey rectangle button on the left hand side, then pull toward you the right hand rectangular button then push this button downwards,
Then, withnthe two buttons still pushed in, with your full body weight, push the chassis downwards the floor until fully folded.
I hope this helps.
SOURCE: replacement foam for quinny buzz handlebar
Hello
I am making handle bar, bumper bar and frame
covers for the bugaboo and can probably help you
with a cover. Contact me at www.bbsprouts.com
Diane
