Question about Dell Alienware Computers & Internet
How do I get my disc out of laptop, it is not a tray, it just slides in and I don't know how to get it out
I slid the disc into laptop and it wont come out, it is not a tray, it just slides in but I cant find out how to remove it from laptop
  • Dell Master
  • 5,571 Answers
Hi judy, if you could let us know the make/model number we should be able to help!
Posted on Nov 12, 2014
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
I can't for the life of me see where the disc tray sits in the MG5200 printer. The manual instructions don't help
Hello.
There are two doors in the front of the printer. the main one that catches the paper, then inside this door, hinged just above where the normal paper is ejected from, is another smaller door. open this and the disk tray slides in there.
Hope this helps Regards GM
Aug 01, 2011 | Canon Pixma MG5220 InkJet Printer
How to take laptop hard drive out ?
Turn over the laptop. you should see a rectangular lid with usually two screws holding it down. remove the screws. lift up the lid and slid the hard drive away from the connector. they are usually mounted in a tray. remove the four screws holding it in the tray. mount the new hard drive the same way as the old one was in the tray. then reverse the removal instruction to reinstall it. careful you don't lose any of the screws. this is general instructions for most laptops. my old dell inspiron hard drive mounted from the side of the case but again only two screws held it in.
Jun 14, 2011 | Compaq Presario 700 470024-192 Notebook
How do you replace a hard drive on toshiba 1715 xcds
Before starting you will need to make sure you have a small cross-head screwdriver. Also make sure that you do not have wet hands!
Power off the laptop and unplug it. Turn it over so that the base is facing upwards. Now look for a panel with a Hard Disc Drive symbol on it, the symbol will look something like this:
http://www-307.ibm.com/pc/support/site.wss/cobn-3h8ccv_4.gif
Remove the screws from this panel (making sure to put them somewhere safe so that you son't lose them). You should then see something like this:
http://uk.coolest-gadgets.com/wp-content/uploads/2009/03/4opendrive.jpg
Its them simply a matter of sliding the disc drive out from the contacts (in the photo above you would slide it to the left, if it doesn't seem to work one way try the other, it may need a firm push, but don't be too rough). One the drive has been slid away from the contacts, simply lift it out.
The drive will almost certainly be in a "cradle", a metal panel screwed to the hard disc which keeps it in place when the computer is assembled (see photo below).
http://uk.coolest-gadgets.com/wp-content/uploads/2009/03/6ssdincradle.jpg
You will need to remove the cradle, which will involve removing about 4 screws from the long edges. Do not lose the cradle or the screws. Also take note of the orientation of the cradle with respect to the hard disc, as to put the new one in, you will need to put the cradle on the new drive before putting the drive into the laptop.
Just follow the above instructions in reverse to put the new drive in. If you need further guidance, the tutorial below is quite good (its where I got the images from):
http://uk.coolest-gadgets.com/replacing-laptop-hard-drive-with-ssd-in-pictures
Good luck.
Jun 03, 2011 | Toshiba Satellite 1715XCDS Notebook
I want to buy a recovery dics for toshiba laptop satellite l675d - s7052. But i don't know where it's bought.
I do not believe Toshiba sells recovery discs, instead they have a utility called Toshiba recovery disc creator. Which should already be on your laptop if not download from Toshiba website.
May 11, 2011 | Toshiba Satellite L675D-S7052 Laptop
How does dvd,cd seat in optical drive drawer?
Label side up, press the disc onto the hub in the center of the open tray. it will snap into place. (Be sure to support the tray, as some discs press harder than others, and you don't want to break the tray.) Slide tray into laptop.
Removing the disc is done by pressing the eject button, sliding the tray out, then grasping the outer edges of the disc, and pulling up, while simultaneously pressing down on the hub with your index finger.
Apr 21, 2011 | ASUS N53SV-XV1 Versatile Entertainment...
Slide tray won t seat on projector
Try a couple of things:
1. Turn on the projector & cycle it in "Reverse" 3 or 4 times (without the tray). Do the levers that move the tray move correctly? If so, do you have another tray you can try? If another tray works correctly, follow Step #2.
2. The 140-Tray has to be in the "zero" position for the tray to seat on the projector. Check to make sure the Locking Ring (the ring is in the center of the tray & keeps the slides from coming out) is TIGHT on the top of the tray. Once checked, turn the tray upside-down. Refer to Page 8 in your owners' manual (if you don't have one, I've made an image of the page, below). You have to make sure the plate on the bottom of the tray is lined up at the notch at shown.jauburn_12.jpg
If this helps, please leave positive feedback for me @ FixYa.com. If you need more help, please re-post!!
Apr 13, 2011 | Kodak Carousel 5600 Slide Projector
I placed the CD in the CD driver and slid it into the laptop. The CD itself did not play and when I went to press the release button in the CD driver so that it would slide out again it became jammed
Hi, there is a small hole located on the front of all cd/dvd drives. With a paperclip you can open the disc tray by pressing the release mechanism through the hole (note press hard, it won't damage it).
Mar 20, 2011 | ASUS (CD-S450) CD-ROM Drive
My console wont read any of my discs
Typically its a problem with the disc tray, a variety of solutions can be gently tapping on the top of the xbox immediately after the disc tray closes. Another suggestion is, and don't do this very often, but when the disc tray closes, immediately turn your xbox 90 degrees backwards so the Disc tray is facing up at the ceiling. If these fail, you may simply just have to play with the disc tray, grab it while closing, dont tug too much, slam it closed really fast. Microsoft really is **** when it comes to making things last, but these should work somewhat, you might just have to buy a new xbox if they don't ever work.
Feb 09, 2011 | Microsoft Xbox 360 Console
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
