Cell Phones Logo
p
peggy Posted on Nov 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Access phone entries - Cell Phones
Richard
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 202 Answers
  • Posted on Nov 12, 2014
Richard
Expert
Level 2:
New Friend:
Cheetah:
Answers
202
Questions
0
Helped
50273
Points
432
The Phone line is loaded when connected to the RE-1
try calling linear;s tech service support today and walk you through use a good 100 dollar multi-meter to check out going devices at dmarc and the device blessings friend!
Phone stuck on voice setting
If you mean VoiceOver, you can go to the Settings app, under the General tab. There should be a subdivision of the General tab named Accessibility, where the first entry will be VoiceOver. You can tap on that to turn off VoiceOver.
Settings -> General -> Accessibility -> VoiceOver -> Off
I cant set gprs in my phone
Open Menu? Settings? Configuration? Personal Configuration Settings To create a new entry click Add new, or go to Options and select Add new From the list, select Access point Set Account name as "Tata.Docomo.Internet" Then, select Access point settings ? Bearer settings, and set Packet data access point with the appropriate setting.
For example: "tata.docomo.internet"
Access to reject list
this should work,go into settings,then call settings,then all calls and auto reject and then click on your reject list,i hope this helps.
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
1helpful
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Please Help
well..try flashing ur phone..!!
or else  restoring it to factor default thing!!
by flashing ur phone will v a DAMN new one..!!
just like formating ur PC, installing new OS.
good luck Sir.
Phonebook
If you tell you phone company, they would most likely replace your phone for free if you tell them that its defective. T-mobile does it for sure. Hope I helped. =)
PhoneBook access problem
You'll need your security code. If you didn't make one try "0000" or "the last 4 of your phone number". 1. Press menu in the "stand by mode" 2. Select "settings" and "security settings" 3. Select "Memory" if will ask for your code. 4 you now have the option of either using the "phone memory" or the "SIM memory" or "both". Try both. See what happens then try phone only. Its up to you. Here's the link: http://nds1.nokia.com/phones/files/guides/Nokia_3200_UG_en.pdf
Aug 20, 2007 • Nokia 3200
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
