Question about Peavey ELECTRONICS CORP. PV215 Dual 15 Inch professional three way spe
How do i connect peavey 215 speaker to sony str-de445?
2 Suggested Answers
  • 1138 Answers
SOURCE: run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Posted on Jun 23, 2009
Wich componet need to change if no sound for front left speaker no sound
check the speaker connection,check the speaker resistance,if it found ok.then open the av receiver top panel and check nearer component of left speaker connection.check the out put power ic .
May 24, 2014 | Sony STR-DE445 Receiver
Sony STR-DN1010 with RCA output jack to Peavey PV-215 speaker input jack
is this a line level out put on the Sony? all the amp outputs on this unit use Banana Plugs, you will need an amp some where if it is. This speaker is not powered.
Jul 25, 2013 | Peavey PV-215 Dual 15 2-Way Speaker...
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
NO SOUND FROM REAR OR CENTER SPEAKERS.JUST THE FRONTS AND SUB WOOFER WORK.
have you checked the wiring of the speaker some time the can cut internally so to check use a small wire and connect just like the one which is in the manual this Can solve the problem
Nov 19, 2009 | Sony STR-DE445 Receiver
No sound from the center speaker
Make sure that your surround setting is set to a dolby movie setting or neo six cenima. If that doesnt do it make sure all the speaker connections are right and that none of the speaker wires are touching one another.
Jul 24, 2009 | Sony STR-DE445 Receiver
Cant get sony sub woofer model no. ss-wg60 working on my sony receiver model no. str-de445
First, go into the "setup" mode of the receiver and go to speaker select, then toggle to sub, highlight and make sure it's "on" Then toggle to speaker volume and check the sub level. Maximum setting is "0". Make sure you are connected to the subwoofer output on the receiver as well. If you still have a problem, post a comment and I can help you some more.Hope this helps
Jun 20, 2009 | Sony STR-DE445 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Jan 07, 2009 | Sony STR-DE445 Receiver
Receiver str de 445
Hi - You can download the manual from the link underlined in blue below:
STR-DE445
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Sony STR-DE445 Receiver
Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
Aug 04, 2008 | Sony STR-DE445 Receiver
Peavey ELECTRONICS CORP. PV215 Dual 15 Inch professional three way spe Logo
43 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
