Installing new ink cartridge in HP 4500 descktop
    Problem Solver:
  • 6 Answers
Go to Google then You Tube then ask same question.
You will be able to watch videos that clearly demonstrate installation process
Posted on Nov 12, 2014
patemi
  • 366 Answers
SOURCE: hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
Posted on Feb 09, 2009
CompuFirm
  • 89 Answers
SOURCE: Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
Posted on May 27, 2009
websnail
  • 419 Answers
SOURCE: HP Officejet Pro L7780 sucking out ink of new ink cartridge
Is this a refillable cartridge you're using or a genuine HP OEM...
If it's a CIS, refillable or some kind of cartridge which is not made by HP then chances are the ink nozzle has failed and allowed the yellow ink to leak everywhere...
There are a lot of problems with these 3rd party cartridges and I would never recommend using anything other than a refilled HP cartridge or a genuine one.
Hope that helps.
Martin
Posted on Jul 11, 2009
  • 157 Answers
SOURCE: new ink cartridge won't print
Do you know for sure the original cartridge was empty? Take a clean pencil with eraser, and gently "erase" the electrical contacts on the cartridge and the printer where the 2 connect. See if that helps. If it is USB, unplug it and plug it back in. You might try to uninstall and reinstall the driver for the printer.
Posted on Aug 26, 2009
SOURCE: HP Designjet T610
NECESITO UNA SOLUCION PARA MI PLOTTER T610 CODIGO DE ERROR 22.1:10
Posted on Nov 14, 2009
HP 4500 PRINTER DOES NOT RECOGNIZE MAGNETIC INK CARTRIDGE
you need a new toner cartridge chip for the C4127X toner cartridge.
After you buy it you will have to replace it.
Best regards,
Marius
Nov 26, 2016 | HP LaserJet 4500 Printer
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
How do i find ink levels in Windows 8 for HP Office Jet J4580
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
The exclamation mark is on and the screen is flickering hp j4580 officejet all in one
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
Jan 10, 2013 | HP OfficeJet J4580 All-In-One Laser...
My hp officejet j4580 says incompatible black ink cartridge
I've been in print cartridge hell since I bought a J4580.
I spent an hour on chat with HP customer service and was able to resolve the problem by partially resetting the printer. Here's how:
  • Make sure your print cartridges are installed.
  • Unplug the machine, wait 20 seconds
  • Press and hold the # and 3 keys
  • Plug the machine back in
  • You'll see a reset message on the machine, release the # and 3 keys
  • Follow the prompts to set the language and location
Cross your fingers, hopefully your printer will print now!
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
Incompatible cartridge error in j 4580
refix your cartidge .may be your cartridge is faulty.
Dec 25, 2008 | HP OfficeJet J4580 All-In-One Laser...
27 people viewed this question
jasbo
jasbo
