Hello my ciac wall mount unit freeses at the evaporater.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 54 Answers
Ciac air conditioner ff error code
FF code means blown or missing damper fuse. Replace damper fuse (inside equipment cover plate) and try again. If damper fuse blows again, find and fix the problem causing the fuse to blow.
Mar 27, 2014 | Carrier Heating & Cooling
CIAC High Wall H3 Error. Will not cool.
my CIAC wall mount unit evaporater is freesing what can it be.
Aug 16, 2013 | Heating & Cooling
The inside front when you open the panel has snow ice formed inside. Is this normal and I have never noticed it before or what is wrong. After we let it unfreeze then it will work fine then freeses again.
Hello, the evaporator coil will frost over for one of 2 reasons, either lack of airflow or low refrigerant charge. start by checking the air filter and clean if dirty, also I would recommnd spraying a coil cleaner on the evaporator coil and clean it. If the unit appears clean then most likely the unit has a leak and will need to be recharged with refrigerant.
Jun 06, 2011 | Haier ESA3125 Wall/Window Air Conditioner
HELLO I HAVE A SAMSUNG 24 INCH MONITOR. MODEL P2450H I WOULD LIKE TO REMOVE THE STAND FROM THE UNIT AS I WOULD LIKE TO WALL MOUNT IT, THANKS RICHARD KEENE
The stand is secured to the back of the monitor with screws.
Your wall bracket may need modifications if the mounting holes on the monitor.
Dec 04, 2010 | Computers & Internet
Water
Hello my name is Heath it will be my pleasure to assist you. No there is no need to put water in the air conditioner. You will get condensation in the unit from the humidity in the air condensing on the evaporater coil.
Jul 09, 2010 | Frigidaire FAX054P7A Wall/Window Air...
Evaporater freezes up after running for aa short while
HELLO THERE:
When you set the temperature settings down around 64 or lower the unit will freeze up so i recommend to keep it at around 68 or 70 ok this will keep it from freezing also make sure that the unit is free of any obstructions so the air can freely get to the unit ok?
best regards michael
Aug 27, 2009 | Whirlpool ACM184XP Air Conditioner
TFX25PR TFT25 PR GE Profile 25.2 cu ft no frost Serial GS248611 Model TFX25PRYD WW Water collecting and freesing in bottom of freezer side and running out the front, Drain tube at back is NOT...
Here are som links that will be helpful. I believe ice is blocking the defros condensate dran behind the freezer back wall of the freezer compartment.
Here are some helpful links.
http://appliancejunk.com/forums/index.php?topic=22.0 and http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/ Pour a warm solution down the drain with Clorox and I think that will help too. Hope this helps. Thanks, Sea Breeze
Jul 28, 2009 | Refrigerators
Thermostat wont shut off unit
These units are bad about that. you have to mount the cap sensor in the small tube that runs thourgh the evaporator for proper operation. laying on top of the coil does not let the thermostat sense properly.
Jan 02, 2009 | True 598-TSSU608ADA SandwichSalad Unit 155...
The refrigerator/freezer isn't cold anymore. The light is one. The icemaker is still running, but no ice. The refrig. side started to go first, then the freezer side about 5 days later. Now it just blows...
Remove back wall cover from freezer compartment. Should have a nice even frost pattern. If large amount off ice buildup is on evaporater than air can not flow through entire unit correctly. This means that unit is not defrosting properly. Check continuity on defrost heater, if good replace defrost thermostat, located as a clipped on device at top of evaporater.
Jul 18, 2008 | Refrigerators
Things freese-up in the kenmore fridge
Try turning down the unit a half knotch, 1 full knotch at MAX, the cold air comes from the freezer to the refrig(fresh food) section, its rolls up the back of the wall to circulate it
A fridge that is to cold is usually shown when food nearest the back wall freezes( i get this call plenty times a day, this is the fix)
recommened freezer temp 0-5, fresh food(refrig) temp is 32-40
May 02, 2008 | Amana AFD2535DES French Door Refrigerator
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
