Question about Maytag Washing Machines
Not enough water coming in
Serial number c30630390
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 202 Answers
Check for clog or valve not working
Posted on Nov 12, 2014
Hi I have a siemens fridge freezer and ice maker is leeking water and it come out of despencer serial number is ke07ze26690373 can you help
sounds to me that the water control valve is leaking on the back of refrigerator and causing water to overfill the ice maker. Need model number not the serial number should talk to someone about replacement parts
APPLIANCE 911
Jan 01, 2016 | Siemens Refrigerators
I would like to find a web site for serial numbers on guns that doesnt cost money to find out
The serial number is not enough. Make, model and caliber is also needed. If it came from a dealer, he'll have the information, otherwise no one will.
Oct 02, 2014 | Optics
Whats the value of bulova watch c9671206 ?
NEED MORE INFO. From that serial number, it might be one of the old tuning fork movement watches. If the date code is from M0 (1960) through N6 (1977) it likely is. If so, it has a collector's value. In any case, the exact model, type of movement, and year would be needed to come up with a value. The serial number is just not enough.
Jul 26, 2014 | Bulova Diamond Watches
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Drain valve leaking. Gor replacement part. Cannot get old valve off . Does the whole valve come off , unscrew or pull off? serial number is RN1296A 18392. Will the new part fit the same New...
If valve is dripping, buy garden hose cap and screw onto valve.
Whole valve unscrews counterclockwise.
If valve is plastic, expect it to break off.
If valve is brass, use cheater bar on your pipe wrench.
I don't know that serial number or part number, but drain valves are standard 3/4" pipe thread.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Drain valve can be rusted in place and impossible to remove without draining tank and putting water heater on it's side.
Install new water heater so drain valve is accessible, and buy new water heater with brass valve instead of plastic.
Jun 15, 2011 | Rheem Water Heaters
Problem with Cuisinart EM-100 Express Machine
Confirm one more time that the knob is lined up with the "o" in the middle - if it is leaning even slightly toward the coffee cup icon or the water/steam icon, water may come forth.
If the knob is perfectly in the middle, then the calibration is probably off (although I can think of one other possibility). Rather than deal with an expensive and warranty-voiding repair, I would just call Cuisinart - that unit has a three-year warranty, and I believe every single one of the EM-100's was introduced less than three years ago. Just write down the serial number that is on the bottom of the espresso maker, and call up Cuisinart - no receipt will be required as the serial number will almost invariably be enough in this case. If you live outside of California, you will have to pay for shipping - probably about $25 all together. But you will be getting a brand-new unit in return.
-Tha Mp3 Doctor
Mar 01, 2009 | Cuisinart Coffee Makers & Espresso...
Problem Water Flow in the Cusinart EM-100 Model
I might have answered this one already, but:
-Tha Mp3 Doctor
Mar 01, 2009 | Cuisinart EM-200 Espresso Machine
Reliance gas water heater 40 capicity, has a leak on the top
Most likely only one of the pipes is leaking but weaping enough to cover the top and indented places near both inlet and outlet. This leak has most likely penetrated all the insulation and is a problem throughout the tank wrap insulation...If you are able to blow air continuously long enough to determine which connection is leaking then fix it. It will likely to take quite a while to dry out all the insulation if the water has migrated down into the tank wrap... If you determine that the insulation is waterlogged, you may be able to drill several small holes in the external cover.
good luck
Jan 03, 2009 | Reliance Water Heaters
Laundry too wrinkled
grabbed this of an official whirlpool web site: Clothing in the washer can become tangled and twisted or balled up.
Under certain conditions, a combination of the wash load, the cycle selected and the subsequent load movement can cause
the load to become tangled or twisted.
The wash impeller has been redesigned to make the wash load less likely to tangle under the conditions mentioned above.
Replace the wash impeller with part #W10141017.
willing to bet your serial number is before this number here. easy enough part to switch if its no longer under warr
SERIAL CODE RANGE: Prior to CU39
Remove & destroy
pointer L8178694
dated September 2007
Oct 27, 2008 | Washing Machines
Ideal c24
Call the manufacture at 800-432-8373. They will be able to assist you. Have your model & serial number. Parts may be under warranty.
Oct 14, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
