How I connect my LN-70 to tv - Televison & Video
I have a lennox ln-70 and i get no sound through the hdmi
The output device is not capable of providing audio through the HDMI.
It lacks the internal hardware.
If Yor trying to output the HDMI Audio from the ln-70 then the input device is incapable.
Oct 19, 2014 | Televison & Video
Greenish tint
Might try the color tones buttons on T.V. up or down.
Oct 13, 2013 | Samsung LN-S1951W 19 in. LCD Television
Samsung lcd volumn ok with dvd very low with tv only
What is it connected to when the volume is low? How is it connected
Feb 06, 2013 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN-T4661F will not display PC; displays 'mode not supported'. Using a VGA cable to connect laptop to tv
Look in the manual for the TV and determine which platform is supported. VGA, XVGA, SVGA etc. Set your computer output to the proper mode and the unit should work. Let me know how you make out.
hardrocko
Jan 31, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Could I change NTSC to PAL N my LCD Sansung LN T
NTSC and Pal are mainly related to Cable/Air reception. Unless you are trying to connect a SCART cable, you can probably just use the video inputs of the TV. Power Supply differences will be the big issue probably.
Jun 21, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Color issues
Need to check the T-con board & main board.
Normally possibility of T-con problem is 70%
Feb 03, 2009 | Samsung LN-T3253H 32 in. LCD Television
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=LN-S4696D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-S4696D
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
Feb 18, 2008 | Televison & Video
LN-T3253H issue with camcorder
Samsungs will not switch to an input that has no signal going into it. Try putting the cables into the TV, then hit play, then switch to the correct camcorder input.
Dec 24, 2007 | Samsung LN-T3253H 32 in. LCD Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
