Question about Ovens
Outside temp is 5 degrees too low.
I have always felt it was reading the temp wrong so I added another thermometer outside as yes, my remote one is 5 degrees too low. I there a setting to make an adjustment?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 202 Answers
Check manual for calibration
Posted on Nov 12, 2014
aborcass
  • 2651 Answers
SOURCE: Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Posted on Nov 27, 2008
barkencoa
  • 3463 Answers
SOURCE: temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Thanks.
Posted on Dec 18, 2008
  • 58 Answers
SOURCE: Oven heat erratic
no there is not and your unit only has one temp sensor you will have to spring for a new control
Posted on Jan 09, 2009
kachbibi1
  • 979 Answers
SOURCE: Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Posted on Feb 15, 2009
barkencoa
  • 3463 Answers
SOURCE: Oven temp. is off at times, varies how many degrees
Replace the thermostat, and it should solve your problem.
Please rate my solution.
Thanks.
Posted on Nov 10, 2009
Both ovens cannot keep tempreture, even small oven which has been used few times
A variation of 5- 10% is actually normal since the mechanisms that signal the oven to turn on & off need to be great enough to stimulate the heating activation mechanisms. I've also heard that variation of 25-50 degrees is normal. I know this sound absurd. But there is hope. If the temp change is consistent you can anticipate the difference. For instance, I have an oven that always needs 20 minutes more for turkey and another takes 4 minutes less for muffins. The answer is add or subtract based on experience with the appliance. Unless the appliance is outside of the manufacturer's specifications there may not be anything wrong at all. Good Lock.
Aug 13, 2015 | Ovens Ovens
My oven has had three thermostats fitted recently and an oven thermometer is regestering about 50 degrees cooler. what cani do?
To get a more accurate indication, set the oven to 350 degrees. Place your thermometer on the lowest shelf, take a reading. Place it in the middle shelf, wait for it to stabilize (5 minutes or so), take a reading, place it on the top shelf, wait 5 minutes take a reading, Average out all 3 readings, the average should be close to the thermostat setting.
Feb 15, 2015 | Ovens
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
How do you fix the temperature for the whirlpool oven
Buy a oven thermometer to put inside the oven to check the accuracy of your oven temp setting. If the oven temp is not too far off from what your oven thermometer is reading, you can recalibrate the oven knob. Pull the knob off and look at the back. You can adjust the degrees approx +or - 20 degrees. If the temp is all over the place or just not heating up enough, then it's time to replace the oven thermostat, assuming the oven isn't too old or not worth fixing.
Douglas
Oct 05, 2010 | Ovens
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
Oven - Failed baked goods, takes too long on other things
most ovens have what is called tempture sensor,its job is to read the tempture within your oven if this sensor is faulty then it sends the wrong signal to your display,you talk about a thermometer showing a different temp please do not put this thermometer in your oven some of these contain mercury and could explode in your oven.I would advise you to call a electrication and get him to test your tempture sensor.sorry i cant help you any better.adrian
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not achieve setpoint temperature.
You may not need anything. Most people test their oven with a dial type oven thermometer. They are slow to react and often not very accurate. When I test an oven or install a new thermostat, I use a digital thermometer with a remote temperature probe, hanging from the center of the oven, which shows the temp in tenths of a degree. I let the oven cycle on and off at least three times, then take the high and lower readings on the next cycle and average that out to see what the actual oven temp is. Most of the time, if there is a dial type thermometer in the oven it is very slow to react. After 3 to 5 cycles, they often show close to what the actual oven temp is, but the only way to know for sure is to use the more accurate digital thermometer. Most ranges with digital displays can be adjusted + or - about 35 degrees. Check your users manual for this info, but don't mess with it until you have checked the oven with a digital thermometer! Please don't bother rating this solution, as anything but a Fix-Ya drops my score. Thanks.
Jan 08, 2009 | Amana Ovens
Oven heat erratic
Jan 07, 2009 | Ovens
Temp indicator chimes although temp is really 100 degrees low.
Thanks.
Dec 18, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
