Question about KitchenAid KP26M1XPM Professional 600 Series 6Qt Stand Mixer
One speed on slide switch will not go high or low
    New Friend:
  • 5 Answers
It's most likely a bad sensor. If a new sensor doesn't fix the problem, then the circuit board would have to be replaced as well.
Posted on Nov 20, 2014
How come my Hobart d340 mixer is only running on high speed
Because either the low speed windings or low speed control is kaput.
Mar 03, 2016 | Hobart Food Mixers
Kitchenaid mixer will not run on speeds LOW SPEEDS only runs on speed ten. I've replaced the phase board and that was not the issue. what else could be causing this problem
If it does not start at all until you get to speed 10 then look for a broken wire an any of the wires NOT associated with the phase board. Highly unlikely since you have just been there. Next look at the operation of the switch low down inside the black speed control board. There is a primitive switch there operated by a shaft from your speed control lever. You may find the switch is not activating until it gets right up to speed 10. Have you checked the carbon brushes? The phase board you have just done is normally the culprit for your problem.
Dec 20, 2014 | KitchenAid KSM75WH WhiteTilt-head Stand...
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
My kg25h7x varies the mixing speed on its own
The Kitchenaid uses a centrifugal switch to maintain a constant speed. This must be sticking to cause this. You mixer will need to be disassembled and inspected.
Jul 03, 2012 | KitchenAid K45SS Classic Stand Mixer
Mixer works on high speed but not low. Brushes
Motor brushes are fairly cheap to buy. It sounds like the first place to start: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
Jan 11, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My mixer will only run on high speed. The other two speeds (low & med.) do not function
check the warranty? it may be still covered, sounds like a replacment switch/unit required.
Aug 16, 2009 | Braun Food Mixers
Kitchen aid KSM90
If you can unplug the mixer and test resistance between leads of the selector switch. The resistance should vary from high to low as you move the selector from low to high. If cord and all else looks good and switch is bad replace the switch.
Mar 23, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Bottom Slide Cover (Part 2a in the manual)
See the description for the speed problem and repositioning of the slidere at this link. The slider should snap back in place easily if everything is ok. The slider also operates a switch inside the mixer. This switch is intended to only allow you to run on full power when using the hand blender. You may need to open up the mixer to check this switch is not stuck in the activated position permanently. Otherwise consider the description of the speed problem in the link.
Jun 17, 2007 | Braun M880 MultiMix Hand Mixer
KitchenAid KP26M1XPM Professional 600 Series 6Qt Stand Mixer Logo
85 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
