Question about Panasonic Plasma Lcd Tv Remote Control N2qayb000100 Th-42pe77u N2qayb000102
Panasonic TV remote unable to get 21-2, 21-3. 21-1 no problem
Is it possible to use this remote to get -2, -3 channels?
  • Panasonic Master
  • 5,503 Answers
Hi Robert, not clear as to your problem! Are you trying to enter 3 digit numbers on your remote?
Posted on Nov 12, 2014
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
What caused no sound on ABC channels 2 and 21 only?
You would need to ask the broadcaster of the stations that question.
Mar 24, 2017 | Televison & Video
I tried auto programming my tv but I can't go past channel 69. All other tvs go up to at least 99. When I try to manually program 99, the remote will only input a 9.
There are only a possible 48 channels available in the UHF bands IV and V; 21 - 68. Some Continental TV's still use band III; 1 - 20
Are you sure you are not getting confused by programme numbers which can go up to 99 and AU etc.
Jan 04, 2011 | Panasonic CT-27E13 27" TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
Channel stuck problem
How long does it take (in seconds) before it changes teh channel? Because some TV's, if you have more than 10 channels, have to wait before they change because you might want to change to a higher channel Example:
suppose your TV has 99 channels but your remote has only buttons from 0 to 9. So if you want to switch to channel 7 the TV waits a little before it actually switch to 7 because there might come another nuber after the 7 as the TV doesnot know what channel you wants. 2 to 3 seconds should be the maximum delay.
If it takes more time, check if this can be changed in the menu, often there is a delay possibility in the setup menu.
If teh delay is over 4 seconds and you still have warranty on it, just return it to the vendor.
Jan 16, 2009 | Samsung 21" FLAT CRT COLOR MONITOR
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Unable to tune channels on a Philips Combi TV/VCR 21''
To cancel the hotel mode, select program 38 again and press the 2 keys as before for 5s * The sign H- appears on the screen and the hotel mode is deactivated
Jun 24, 2017 | Philips 21PV375 21 in. TV/VCR Combo
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Mar 19, 2008 | JVC RM-C18G-1H Remote Control
Panasonic Plasma Lcd Tv Remote Control N2qayb000100 Th-42pe77u N2qayb000102 Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
