What problem of error code 2 blinks of cassette type
    Top Expert:
  • Televison & ... Master
  • 74,384 Answers
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Posted on Nov 12, 2014
My Panasonic cassette sc timer light blinking what is the problem
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Sep 23, 2016 | Panasonic Televison & Video
Why tv sharp lc-80le632u when its starts it appear this blinking error "Power supply error 2 D+3.3V error"
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 16, 2016 | Sharp AQUOS LC-80LE632U 80" 1080p LED-LCD...
Sony blinking code on sony trv128 handycam.C31;22,and reinsert cassette,after falling on the carpet..plays for about 20 seconds,then stops and flashes the code...help?
Blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 04, 2014 | Televison & Video
How to programURC 5600B00 remote to bell receiver
Turn on a device (e.g.,VCR) and, if
applicable, insert media, (e.g.,
cassette or disc).
NOTE: Please read steps 2-4 completely
before proceeding.Highlight or write down
the codes and device you wish to program
before moving on to step 2.
2. On the remote control,press a device
key once (i.e., VCR,DVD, TV,or
CBL/SAT ).Press and hold SET until
the LED blinks twice, then release
SETP.
3. Use the Manufacturer's Codes to
locate the type of device and brand
name and then enter the first fourdigit
code for your component. If
performed correctly, the LED will
blink twice.
NOTE: If the LED did not blink twice, then
repeat steps 2 through 3 and try entering
the same code again.
4. Aim the remote control at the device
and press POWER once.The device
should turn off. If it does not respond,
repeat steps 2-3, trying each code for
your brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
POWER key, press the (Play) key.
5. Repeat steps 1 through 4 for each
device you want to control.
Jun 16, 2012 | Televison & Video
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
I need the codes for a Zenith TV and Emerson VHS player. I don't have the book that goes with the URC-4110B00 Universal One For All Remote.
Zenith TV - 0017, 0092, 0178, 0463, 1265
Emerson VCR - 0000, 0037, 0043, 0121, 0184, 0209, 0593, 1278, 1479, 1593
And the instruction in case you don't know how to program code.
1. Turn on a device (e.g.,VCR) and, if applicable, insert media, (e.g.,
cassette or disc).
NOTE: Please read steps 2-4 completely before proceeding.Highlight or write
down the codes and device you wish to program before moving on to step 2.
2. On the remote control,press a device key once (i.e., VCR, DVD,
TV,or CBL/SAT ).Press and hold SET until the LED blinks twice,
then release SET.
3. Use the Manufacturer's Codes (starting on page 12) to locate the
type of device and brand name and then enter the first four-digit
code for your component. If performed correctly, the LED will blink
twice.
NOTE: If the LED did not blink twice, then repeat steps 2 through 3 and try
entering the same code again.
Feb 06, 2011 | One For All URC4110 Remote Control
My Sony CCD-TRV16 NTSC Video 8 keeps blinking C:31:00. Battery is charged. Won't stop blinking?
this is listed as a serviceable error code by sony . . they say to remove the cassette and replace .. if that doesnt help try another cassette .. also remove power including battery for a minute .. then re apply power .. that will reset the system ..
you can get a nice free service manual here
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CCDTRV16
cllick on "operating instructions (primary manual) then go to page 71 where your error code is mentioned
this is in PDF format so you need "acrobat reader" if you dont already have it, its a free download available also on that site ..
Jan 19, 2010 | Video Cameras
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
We own a Sony handy cam model CCD-TRV37 and the tape will not come out. When pressing the eject button a little yellow arrow blinks upward on the screen and a code C:32:20 blinks in the upper right corner....
Error C:32:20 indicates that the take up reel of the cassette that winds the tape into the video cassette is not taking up the tape fast enough thus causing slacking when unloading.
Remove the battery or power cable, connect, and perform operations from the beginning.
if this fails take the camera to a repairman to remove the tape manually.
Dec 01, 2009 | Video Cameras
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
