Question about Canon 2 Ir3300 Ir3300i B/w Copier/ Network Printer & Fax
When I give copy command on my ir 3300 page will not comes out through fixing unit and shows paper jam error
    Champion:
  • Canon Expert
  • 234 Answers
Maybe something wrong with fixing unit.Check if it rotates
Posted on Nov 12, 2014
    New Friend:
  • 38 Answers
The Bridging unit and finisher could be misaligned
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
ctf1800
  • 4402 Answers
SOURCE: ir 3300 paper jam
the heater section is the fuser you should be able to pull the tray out and then lift the door of the fuser
Posted on Sep 03, 2008
futureloginn
  • 734 Answers
SOURCE: paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
SOURCE: i have canon imagerunner 3300 it shows error E000100-0002
E000100-0002
Posted on May 26, 2010
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
My iR 3300 is very slow How can I make speed
dear
pl. do setting for image type to text or text/photo. the curling of paper mostly due to the fixing film unit. the pressure roller may softened. replace it or the path have toner clogged clean it with alcohol.
thanks.
Mar 04, 2015 | Canon Ir 3300 Black & White Copier
Canon ir 3300 have a problem for paper jam in fixing film so how to solve the problem
there is an error in the rotation of the fixing film.
check the fixing film sensor and make sure that all the wiring and the connectors are connected securely.
if it persists, consider replacing the fuser fixing film
thanks
Aug 17, 2014 | Canon IR 3300 Digital Copier
Error code e000007-0000 in caonon ir 3300
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
Jan 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Black bande IR 3300
Most probably you need to replace the drum unit. If you have any idea what was the copy count when the drum was last replaced and since then around 50000 prints are done, new drum is needed.
Apr 28, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon 2 Ir3300 Ir3300i B/w Copier/ Network Printer & Fax Logo
63 people viewed this question
old marine
old marine
