I have a harman kardon avr2511 and the power supply board is no good... is there a replacement part that would be Compatible?? I talked to harman and they dont make the part anymore and wont help me find a compatible part
    Top Expert:
  • Audio Player... Master
  • 75,178 Answers
Contact the authorized service centre for Harman/Kardon.
Posted on Nov 12, 2014
SOURCE: Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Followup on higlider's problem. Now it has to be turned on ten times before it stays on. Email from Harman Kardon only suggests taking it to an authorized repair shop. It is clear that it is not from speaker short or overheating, because it only happens when the rcvr is cold.
-higlider
Posted on Jan 05, 2008
im4um2
  • 77 Answers
SOURCE: When I go to power
Depending on your ablilities there might be a quick fix. It sounds like the contacts in your on/off switch are either corroded or worn out due to heat. Ensure the unit is unplugged from any electrical source. By opening up the unit you will have to detach the on/off switch, and by bending the prongs carefully, open the casing up. Clean all internal part using contact cleaner. If the contacts are worn or corroded, you can try replacing or what I did was added some solder to the contacts and put the unit back together reversing my steps.
Good Luck.
Posted on Jun 27, 2008
smarthome2
  • 1114 Answers
SOURCE: Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Posted on Jul 01, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
  • 382 Answers
SOURCE: Harman Kardon HK 3270. The receiver looses the
I believe it is actually a memory capacitor that has to be replaced. It is soldered directly into the board and requires quite a bit of know-how to replace.
Hope this helps,
Thanks,
Posted on Jan 20, 2010
My Harman Kardon is AVR 151. It's not on. the power led is blinking. Sometimes it work correctly.i don't know what to do. please help!!!
Normally its a power supply that does that its protecting itself from further damage you will have to check the transformer or power supply in the unit normally it would be blown capacitor s
Sep 03, 2016 | Harmon Kardon Harman Kardon AVR1510...
On my Harmon Kardon 45 I push in the main power button and nothing happens
Hi
the device is in protect mode
1: speaker wires
2: Faulty power supply and usually this is the problem.
there is an internal power supply for +15 and -15 volts regulators.
on the main board .
need to be replaced
Good luck
Apr 15, 2015 | Harman Kardon Audio Players & Recorders
Harman Kardon 146 receiver not turning on.
Possible blown fuse inside unit, unplug and remove the top cover
fuse should be near the power board and transformer. replace with exact fuse, "Never remove covers with the unit plugged in" Always wait 4 or 5 minutes after unplugging to remove the cover.Replace cover before plugging unit back in.
Oct 06, 2014 | Harmon Kardon Harman Kardon Avr 146 5.1...
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
I need the whole printed circuit board of the power transistors for my AVR 200 Harman Kardon receiver ? Any available ?
Not unless you can find them second-hand somewhere. Harman-Kardon doesn't supply boards as replacement parts.
Mar 22, 2013 | Harman Kardon Audio Players & Recorders
Is it possible repair a power supply of Harman Kardon?
You can certainly try replacing the capacitors, they should have the values written on them, but be aware they are glued/epoxied as well, to reduce vibrations..
My supply has also failed - after verifying that the speakers were otherwise functional (using a 19v supply and 16v regulator, which got pretty hot)), I ordered a new one from ebay for $26 shipped.
Aug 30, 2012 | Harman Kardon SoundSticks Computer...
Harman Kardon SoundSticks II Computer Speakers
Hello
It seems that the power supply section of your speaker systen has the fault. Check the fuse inside it. If it found blown out, never replace an other fuse in place. Check the power supply circuit board for any short circuited components in it, before replacing an other fuse.
Mar 21, 2012 | Harman Kardon SoundSticks II Computer...
Need the AC 15V 1.1a power supply
Hi Tracy,
Wow, this was a hard one. I called both Harman Kardon and Dell, seems HK made the speakers for Dell, but neither company carries parts any more. I called Radio Shack thinking they would have a generic power supply, not even close. I looked at several places on the internet and had no luck.
I do have a little good news, I was able to find a few on Ebay, so if you don't mind buying used, you can get a power supply there. They even have a Buy Now offer so you would not have to bid on it. The power supplies are listed as 1100mA which is the same as 1.1A.
Also, if you get the it and the plug in is not the right size, take the speaker to Radio Shack and they will be able to sell you the correct plug, all you will have to do is splice in the new plug. With it having an AC output, you don't even have to worry about the wires being crossed as you would with DC. Hope this helps you.
Here are the links:
http://cgi.ebay.com/Harman-Kardon-A481511OT-15V-1100mA-Black-AC-Adapter_W0QQitemZ190450725250QQcategoryZ79846QQcmdZViewItem
http://compare.ebay.com/like/370463130288?ltyp=AllFixedPriceItemTypes&_dmd=Gallery&var=sbar&rvr_id=189044360544&crlp=1_263602_304692&UA=L*F%3F&GUID=0234523512d0a0b3f8f79f17ff3c9895&itemid=370463130288&ff4=263602_304692
http://cgi.ebay.com/Harman-Kardon-A481511OT-HK-01T-AC-Adapter-15V-1100mA_W0QQitemZ190450725272QQcategoryZ79846QQcmdZViewItem
Dec 23, 2010 | Harman Kardon HK19.5 Computer Speakers
60 people viewed this question
 Grubhead
Grubhead
