<!-- from fixya rte -->Whirlpool awm5104/3 water leaking at filter - Washing Machines
2 Suggested Answers
SOURCE: Water filter leak Whirlpool ed25rfxfw01
I have an undersink filter from Whirlpool that is leaking also. I had an older one that also leaked and I replaced it. Worked fine for about six months then water all over under the sink. I believe it is leaking from the O-ring which seals the body and the cap. I think they have a lousy design and will look for another filter.
Posted on Jan 01, 2010
Why does water filter leak when tightly connected but not when loose?
It makes sense if there is a crack in the filter housing that is made more severe by tightening the fitting. Also, a fitting could be stripped from overtightening.
Aug 11, 2015 | Whirlpool Refrigerators
Can the water filter housing be the cause of slow water when the filter is in place?
Even a new filter will reduce the flow some what. I think the pressure to the filter is low or restricted . that will cause a reduction in flow, no it should not leak, check on the seal.
May 27, 2015 | Whirlpool Refrigerators
My Whirlpool side by side refrigerator is leaking water down around the filter. When I remove the filter, the water stops.
There was some issues with filter seals some years back and the filters had flat spots and caused the to leak. So if you are using a factory filter you can return it to the parts distributor and they will replace it. If its a after market filter I don't know what to say but us a factory filter to fix this issue.
Good Luck
Oct 26, 2013 | Whirlpool GX5FHTXVA Bottom Freezer French...
Mod.g17fvcxw001 leaks water from vents inside between light and water filter.
Hi,You will need to look at either the filter or water line too and from the filter housing for the leak. I have seen filters with flat spots on the "O" rings that will cause them to leak, even brand new out of the box.
Good Luck
Oct 08, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Whrilpool refrigerator, model #
the drain hose to the base is plugged that sends water to the lower area by the floor to evaporate
Aug 01, 2010 | Whirlpool Refrigerators
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Three year old Whirlpool Refigerator (ED5FHEXNB), water leaks from bottom of refigerator when outdoor garden hose water is turned on. Only leaks when outdoor garden hose is turned on. Water filter, Brita...
Hello it sounds like you have a leaking water hose which you need to find. maybe check first where it connects into the back of the unit.. Otherwise the fridge has a blocked drain in the freezer. cheers
May 15, 2009 | Refrigerators
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water filter housing leak
Leak just stopped on its own. No idea why.
Oct 10, 2008 | Whirlpool GD2SHGX Refrigerator
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
