Question about AO Smith Miller / LSI / Home / Nordyne Replacement Furnace Motor 1/5hp 1050 RPM 115 volts OML64
Furnace will not stay lite, flashes pressure valve closed
Furnace lites and than the fire goes out, codes the pressure valve closed
  • 42 Answers
Too much or too little pressure. Check for air blockage or an ice blockage inside or outside the house. Were flames good color when lit?
Posted on Nov 26, 2014
Orange lite flashing when burner is on
WHAT MODEL AND BRAND FURNACE DO YOU HAVE ? USUALLY THE ORANGE INDICATOR LIGHT IS SHOWING THAT FLAME IS PRESENT. USUALLY SOLID ORANGE NO FLASH . INDICATOR LAMP COLOR AND FLASH CODES FOR TROUBLESHOOTING USUALLY ON INSIDE OF ONE OF THE DOORS AND IN PAPER WORK THAT CAME WITH FURNACE.
Jan 01, 2014 | Heating & Cooling
Smart gas valve get 24v. but pilot will not spark or light
Do you have 24 volts at the gas valve terminals when the pressure switch closes?
Dec 17, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Furnace fires but cuts out after 10 seconds. Yellow lite flashing 2 times continuous. Green light flickers and sfter furnace cuts out gos bright green for 2 seconds and then goes back to flickering.
Since you didnt include Brand and Model number, you could check on the inside of'
the front panel you take off to access the furnace. Most have a diagram of the wiring
and will have an Problem Code list that tells you what those flashing lights indicate.
Good luck and feel free to reply with Brand and Model #
Mar 31, 2011 | Heating & Cooling
I have a coleman furnace it comes on the electric igniter glows red the gas comes on then the blower starts and the fire goes out it gives 2 different code for this 1 is ignition failure and the other is...
I would have the ignition control board replaced. That is what tells the gas valve to come on and if there is flame or ignition it will keep the gas on if the flame sensor gives the board a signal that the burner is lite. By you shuting power off and on to the furnace it resets the board and it will go through its cycle again.
Feb 10, 2011 | Coleman Heating & Cooling
Heil 75kbtu gas furnace 80% efficiency installed winter 2004-2005 timeframe. the exhaust fan comes on and the green lite on the valve flashes green but the unit wont fire. a service tech asked if the pilot...
if it has a pilot, you can follow the pilot tube from the gas valve back to the burner assembly and find it. It may not have one and if this is the case, the air flow switch is supposed to close when the inducer fan comes on . If the flue is clogged, condensation in the bottom of inducer fan(would hear cracking). then after the draft safety switch is closed,the gas vavle will get 24 volts and allow the gas valve to open
Oct 27, 2009 | Cross Furnace Draft Inducer Blower 115...
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Laars lite 2 LG or LD Pool Heater- Heater won't stay on
the control module is the problem it allows the heater to come on then turns off power to the gas valve.if you are not getting enough water flow the high limit is turning the heater off then your problem is flow.
Sep 20, 2007 | Lite On Laars Lite 2 Heaters: 250,000BTU...
AO Smith Miller / LSI / Home / Nordyne Replacement Furnace Motor 1/5hp 1050 RPM 115 volts OML64 Logo
95 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
