Question about Stoves 800DFDOm Dual Fuel (Electric and Gas) Kitchen Range
Have been told to get a new dial for stoves 800 dom main oven as this is whats causing it to not shut the element off fully does anyone know where I could get one from
    Master:
  • 876 Answers
Get hold of these people:
http://www.partselect.com/Contact.aspx
Posted on Nov 15, 2014
Eaton viking imperial electric,stove oven door will not close completelty; circa 1996. are replacement hinges still availible?
To the owner of the Eaton Viking stove RS3028W-1, yes you CAN get replacement hinges!
I too, have this stove model (circa 1996) with exactly the same problem and I have spent the past 18 months looking for replacement oven hinges. I was very frustrated at the thought of having to throw out a stove that cooks and bakes wonderfully and has not needed any repairs till now and having to buy one of the new subpar ones that constantly need repairs. Plus you can't do canning on the new stoves and the few remaining coil models are extremely poorly made.
I have found 2 places that carry the hinges.
1. Reliable Parts, 1-800-663-6060. This company is located in Montrea (St. Leonard), Quebec.
2. Appliance Shark, 1-800-663-1176. This company is located in Barrie, Ontario.
The part number for the hinge is: 318-024-741
I hope this is helpful, and may you have many more years of happy cooking on this great stove.
Sep 17, 2014 | Eaton Computers & Internet
Loud pop from Range, stove top still works
The pop was a shorted wire.
The short drew sudden over-amp at breaker.
Amps = heat.
Breaker senses heat and trips before wire to oven is damaged, and before the arcing short can cause a fire.
Was the short at the element?
I don't know, but sounds like the circuit board was damaged.
Of course they are putting electronics inside all appliances today instead of old mechanical dial, because it's cheaper or so much prettier... but new appliances more vulnerable to surge, and other electrical failures. Which is true for all 240V appliances not protected by whole house surge protector.
To test element.
Remove element.
Use a continuity tester across the element connections.
If there is continuity, then the element is probably functional.
Use a multimeter across same element, set multimeter to read ohms.
240 Volt, 3500 watt element should be about 16 ohms.
4500 watt about 12-13 ohms
Volts squared divided by watts = ohms
57,600 divided by 4500 watt = 12.8 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
I would guess that the short fried the circuit board, but there is a also a shorted wire somewhere that is still bare and dangerous while power is ON and you are touching oven or stove, unless 240V breaker is GFCI or arc fault, which probably not. Especially dangerous if you are moving stuff around trying to find problem while power is ON.
Gene
h
Nov 19, 2013 | Frigidaire FEF366 Electric Kitchen Range
I have a whirlpool slid in gas oven. model # GW395LEGQ5 the stove top works great but my oven goes on for about 15 min. or so and shuts its self off. its coming up on the holidays and im a baker so please...
you may need a sensor change if the oven is on and sensor is gone there is a protection on oven to shut down cause of over heating ... i would try un plugging the stove for 10 min .... plugging back in and seeing if it resets ....also make sure when oven is on there is nothing on the element blocking the oven from releasing the heat if this doesnt work may need a new sensor
Oct 23, 2013 | Whirlpool SF368LEP Gas Kitchen Range
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
BE CAREFUL.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
Stove working, broiler working, oven NOT working .. explain pls.
Assumption: This is an electric oven(?).
You seem to be saying that the bottom heating element in the oven is not coming on.
This can be caused by three possible failures: 1. Thermostat (this is the dial you turn to set the temperature); 2. Selector dial (this is the dial you turn to select the mode (broil, cook, etc); 3. the heating element has failed.
My guess is that the heating element has failed (usually the culprit). It is easy to remove.
1. Unplug all power.
2. Unscrew screws at back holding heating element in.
3. Pull heating element out (it may may electrical connection with a jack built into the wall of the oven cabinet or it may have wires you have to disconnect).
4. If you know how to use an ohmmeter, check the element for continuity. It should have some resistance but not MegaOhms.
5. If you don't know how to check, take it to the parts store and let the counter guy check it for you OR just buy a new one and try it out.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | GE Ovens
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Stoves 800DFDOm Dual Fuel (Electric and Gas) Kitchen Range Logo
151 people viewed this question
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
