Question about Craftsman Professional -torque Tested - Air Impact Wrench Tool 3/8 Dr 19916
Handle came loose on my craftsman torque wrench. What is the proper way to replace it? I noticed that the nut on the inside came loose. If I re-tighten the nut will it effect the torque calibration? I
Handle came loose on my craftsman torque wrench. What is the proper way to replace it? I noticed that the nut on the inside came loose. If I re-tighten the nut will it effect the torque calibration? I don't know why but I've only used it twice. I'm thinking someone has turned the adjustment handle until it came loos or the factory failed to tighten properly....
    Master:
  • 401 Answers
I had this problem with mine as well. Most are threaded into the case and don't have nuts inside. I took each bolt out one at a time and cleaned and coated with Blue lock tight and torque back in to factory spec. Just get them snug don't over tighten. Do one at a time so it doesn't come apart. I would have tool recalibrated or at least check it behind a known good torque wrench
Posted on Jan 04, 2015
My 1995 Ford Ranger's windshield wipers don't work
That involves airbag removal & a lot of delicate work. Let someone experienced handle it.
Jul 15, 2017 | Ford Ranger Cars & Trucks
Which way do turn the rear shoe and drum brake adjuster after putting new ones on
You turn the adjuster by hand or with pliers
Then slide the drum on & off a few times, until
the shoes are just touching & barely making a noise
Each side will turn opposite,you don't need to know the
direction,just adjust & try the drum on
You either have to have the drums machined or use a dremel
tool to grind off the step, or what I have told you & done for 48
years won't work
Oct 01, 2012 | Dodge Cars & Trucks
2005 Lincoln LSV8 (3.9) overheating ..no H2o in crankcase, had NO prob. until had P/S hoses replaced is it necessary to take the serpintine off to change the hoses on that motor? i've been told if
I don't know if you have to remove the belt to change the hoses, but I would think the pump would have to be removed to get to the hoses. If that is true then the belt would come off.
And yes the water pump could be running backwards.
It should be a simple task to check the routing of the belt. You should have a sticker on the engine or the hood showing the correct routing.
If not, you can find a diagram online or ask for one here.
Sep 18, 2012 | 2000 Lincoln LS
My transmission will not shift out of second gear. I've changed the filter for the transmission twice. I also changed the fluid and it hasn't helped. I don't believe that the transmission...
Have you checked to see if the linkage is adjusted correctly? If the linkage is okay, I'm hoping it's gunk stuck inside the valve body or other component.
My old fix,tried and true, is to add one and a half cans of `Sea-Foam' TRANSMISSION TREATMENT to a large transmission(10 qt. capacity or more).
By following the directions on the can and running the ****** thru its paces, it might start working for you. don-ohio
Sep 14, 2011 | Chevrolet Tahoe Cars & Trucks
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
I have requirement of region code cracker for sony 3d E370
hi,
To make your BD player you need One for all universal remote control
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
Aug 08, 2011 | Sony Televison & Video
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
Made the mistake of taking our Tri Glide to the Thunderbird Harley-Davidson Dealer in Albuq. NM for it's 1000 mile service. Got it back and the rear end is squeaking like crazy, and the the clutch...
Since your bike is under warranty, I'd take it back to the dealer and tell the service manager about the problems. When you go to pick the bike back up, make sure you test ride then and bring any concerns to the attention of the service manager immediately.
Now, if you want to adjust your own clutch (and now is a good time to learn) follow the clutch cable until you find the clutch cable adjuster. Slide the protector boot up or down to gain access to the adjuster. Loosen the lock nut and turn the adjuster barrel inward and get as much slack as you can in the cable.
Then, remove the derby cover at the primary to access the clutch assembly. Loosen the lock nut on the adjuster screw in the center of the clutch. Turn the adjuster inwards until you feel a resistance. DO NOT FORCE THE SCREW OR YOU'LL DAMAGE YOUR INNER CLUTCH HUB. Turn the screw inwards and then back it out and go back in again until you get the feel of what you're doing. When you feel the resistance, stop and back the screw out one half (1/2) turn. Lock the lock nut down and replace the derby cover.
Go back to the cable adjuster and turn the adjuster barrel outwards until you have about 1/8 inch of freeplay. Lock the lock nut and replace the protective cover.
From reading your post, it's evident that you don't have much faith in your dealership. There are LOTS of riders that feel the same way about their local dealer. With this in mind, I'd advise that you purchase a service manual and learn as much about your bike as possible. A service manual for an Ultra would probably be best in your case.
I am an old school biker and mechanic and I don't work on Twin Cam powered bikes. I try to help when I can though. The computer controlled bikes require special knowledge about how the computers work and since I've got all I can do working on Panheads, Shovelheads, and Evolution powered bikes, I leave the computer bikes to the dealers. I work on the bikes that the dealers will not work on. If you owned a Shovelhead, the dealer will not work on it. That's where I come in. I've got a "niche market" and I stay busy. As for the Trike part of your bike, I don't mess with those either. Sorry I can't help you with that. You'll have to locate the squeak and determine what to do on your own on that one.
Good Luck and Ride Safe.
Steve
Jun 05, 2011 | 2011 Harley Davidson FLHTCUTG Tri Glide...
Made slideshow in slideshow expressions easily. But when try to burn, only the hard drive options shows, not the DVD option. re-installed twice on 2 different computers. one windows-7 on dell xps 8100...
Hello patti3862
I've had this issue before, but only one time and never since. I exited the programme and re-started it and the problem was solved. However, other people have reported it on this forum before and I don't know if they found a solution to this issue. Evidently you've struggled more than I did. Maybe it's a glitch in the software, or there could be something that interferes with the software.
I recommend you contact the technical support team for this software. They should be able to help. I've done this before and was helped out. You first have to register in order to get help, but it is all free and I think really worth the trouble. You can communicate via email, or they could phone you. At first I thought, no, I don't want to go to that kind of lengths, but in the end I'm glad I decided to contact them. The people you need to get in contact with are at Individual Software's website. I think it's individualsoftware.com, but you can Google it to find it fast.
I wish you the best.
From 11407336 (South Africa)
May 07, 2011 | Individual SlideShow Expressions
Craftsman Professional -torque Tested - Air Impact Wrench Tool 3/8 Dr 19916 Logo
88 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
