Question about Garden
Car is not idling. It cuts off while driving, it only goes when foot is on the gas. Diahatsu Charade G200 1998
Need to get a part that will sort this problem out. It seems like it the carburetor and the gas line.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
I am not a mechanic.. but from experience with other vehicles... if battery cable is corroded or loose,, battery weak,, it causes the computer to mess up... Here is something else to try.. I changed my battery in my van also my sons truck.... started them up and they would not idle.. mechanic friend of mine said to do this to reset the throttle body senser..."" Do not start, but turn key to On.. Press the gas pedal to floorboard 3 times,,(not real fast) then turn switch to Off... now start the car as normal.. It works on Dodges I know.. Good luck
Posted on Nov 12, 2014
Why does my 1990 Daihatsu charade want to cut out and stall when giving throttle unless it's in high rpms it doesn't want to go we've replaced the fuel pump and filter could it be the injectors?
Daihatsu Charade low idle problems Questions & Answers ...
www.fixya.com > ... > low idle problems > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks low idle problems questions and answers. ... but idles unevenly with foot on accelerator. does not want to accelerate. please . ... problem daihatsu cherade 1991. when the airconditioner is on the car stalls when changing down to a lower . ... 1990 daihatsu applause 101a 1.6lt 5spd manual.
Daihatsu Charade car keeps cutting out when stop ... - Fixya
www.fixya.com > ... > Cars & Trucks > Daihatsu
Daihatsu Charade cars & trucks car keeps cutting out when stop questions and answers. ... 1997 Daihatsu Charade CS G203 1.5i manual stalling when warm ... gear) while accelerating or when coming to a stop and you take it out of gear and ... 1990daihatsu applause 101a 1.6lt 5spd manual car starts normaly. when auto ...
Nov 17, 2015 | Daihatsu Cars & Trucks
What is the timing and firing order for 1990 diahatsu charade
Firing order is 123 with 1 being the side farthest from the distributor.
Jan 16, 2014 | 1990 Daihatsu Charade
Are there any precautions i need to take when unhooking fuel lines while removing intake manifold from 1990 diahatsu charade 1.3?
just make sure that the engine is not hot and that you use the proper tools for disconnecting the lines.
Dec 29, 2009 | 1990 Daihatsu Charade
Overheating in Diahatsu Charade 92. EFI 16 Valve.
Did you burp the coolant? If not, you have air bubbles in the system that are trapped behind the thermostat, keeping it from opening. Run the car at idle until it's 3/4 of the way to overheating, then shut it down and let it cool. Pop the radiator cap and the air bubbles will burp out. Check the level of coolant in the radiator and expansion tank, top off as needed, and repeat a couple times, and you should be good to go.
Dec 09, 2009 | 1992 Daihatsu Charade
Diahatsu hijet van 1991 need to know pipes where they fit becuse i mess them up and it cannot start
i have 1991 diahatsu hi jet van tempr geting hot after 20 mins and water steaming from silencer
Nov 20, 2009 | 1992 Daihatsu Charade
Specs for 1992 3cyl diahatsu charade ignition timing
Timing set with vacuum hoses disconnected and blocked is 5° advanced when flywheel dimple lines up with notch plate.
centrif wieghts 10.5° @ 2800
vacuum two stage 11° @ -320mmHg.
Feb 19, 2009 | 1992 Daihatsu Charade
Can I put Roof racks on my car?
Yes you Can-Assuming that you can locate a Manufacturer that Makes them for your Model. Try www.JCWhitney.com
Jan 11, 2009 | 1988 Daihatsu Charade
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
