What type of antenna works with the jvc mx-c33
On the back of my jvc mx 200, there is an FM antenna input that says F 750. How do I get it to receive FM broadcast?
Ideally, you need an FM antenna, which is usually a folded dipole loop, looking like a 'T' made of parallel conductor. The input impendance, symbol Z, is usually 50 ohms, so the F 750 may be
F Z50 with bottom of Z not visible.
F=Frequency modulated input
Z=Impedance
50=50 ohms impedance
The number '750' makes no sense, as the FM broadcast band frequency of 88-108 MHz is way below 750MHz (UHF), and impedance at 50R is well under 750 ohms.
Tip:
Although a proper FM antenna is recommended, in good reception areas, such as near a city, a single insulated wire stuck into one 2-pin FM socket or center-pin of a coax FM socket can give reasonable reception.
Dec 18, 2017 | JVC Audio Players & Recorders
Where can I purchase an fm aerial for this jvc
Just about any electronics or big box store (Walmart, Target, etc.) will have an FM antenna. They will be in the electronics section.
Mar 18, 2015 | JVC MX-J30 CD Shelf System
My jvc mx c33 will not play cd's that I burn, plays store bought ones fine. I am using Roxio NXT Pro to make my cd's on to a .cda format. The jvc mx c33 doesn't recognize the disk, just says there is
Are you closing the disc? If so are you using CRD or CRDW. If you are using CDRW it will not burn in the proper output format. If you use CDR only it should. Also try recording at a slower speed. It has helped me in the past to do so.
A great program to try is CDBurnerXP, and it's free. After you record it then put it back in and run it again, but this time just select "Disc" then from the drop down menu Disc Information [CTRL+I] and read what format you ended up with. Remove that and check a store bought disc and compare.
CDBurnerXP Free CD and DVD burning software
Dec 03, 2014 | JVC Audio Players & Recorders
Where OH Where can you buy parts for a JVC MX-C33 compact componet system. I have gone to JVC and they are so very limited!!
Most of these CD drawers are driven by a small belt that's either broken or come off. All you need do is find the belt, measure the diameter in MM and then put "??MM drive belt" into Google. You don't have to be precise with the measurement. So if it's a 45MM a 40 or 50MM will do.
Feb 22, 2013 | Audio Players & Recorders
JVC mx-d761t fuse
are you talking about the internal fuse? or the fuse in the plug
im assuming that you are talking about the internal fuse
get a standard glass tube fuse at the amperage you know about
i belive it does not matter what type of fuse it is as long as the diamentions are the same its good
May 11, 2010 | JVC MX-D761T Shelf System
I just purchased a used JVC MX-C33 stereo and the FM radio is ot working. Do I need to have apecial antenna or other gadget to get the radio to work? DO not have the manual. Thanks
I have a used JVC MX-C33 and put the cartridge in with only one cd and only one tray in the cartridge. Now it wont eject nor will the single slot open. Any suggestions on how to open it? Thanks, Monte
Apr 28, 2010 | Audio Players & Recorders
JVC MX-C33 Tape Drive Problem
there are small rubber belts that drive the tape spindle that makes the tape play! Over time these stretch and become loose and make the tapes play slowly and even shut down (replace belts and it should be fine) these belts are located in back of tape spindel and are about two inches long!
Please rate my answer and keep this site FREE!
Dec 31, 2008 | JVC MX-J30 CD Shelf System
Jvc model mx-c33 home stereo
Did this problem start as soon as you moved it or did it take a couple of weeks? also did it get dropped during the move?
Feb 05, 2008 | Audio Players & Recorders
FM RADIO DOES NOT COME IN
either the tuner is bas or the antenna is not hooked up.
Jan 07, 2008 | JVC MX-GT90 CD Shelf System
47 people viewed this question
 Grubhead
Grubhead
