Flashing green light red ink light on and inks are new
This is second resupply of inks
  • 11,800 Answers
Bad connection between the ink heads and the board - either the contacts in the head carrier are dirty and must be cleaned with a q-tip and some alcohol or the cable connecting the head carrier to the board is broken and the printer is dead.
Posted on Nov 24, 2014
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I installed a new black ink cartridge. The printer won't print. The red ink light is on permanently. I have pressed it for 6 seconds, but it and the green light just flashes continously. I have waited for...
try to clean whit alcohol the contats of the ink cartridge and the place where the cartridge joins the printer, probably there is dry ink on the printer.
Feb 09, 2011 | Office Equipment & Supplies
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
MY EPSON STYLUS C46 WONT ACCEPT THE BLACK INK WHICH IS NEW THIS IS THE SECOND ONE. THE RED LIGHT FLASHES AND THE GREEN LIGHT STAYS ON
Check status monitor? Black ink not recognized or what? If not recognized, red light just on. But flashes? It's may ink nearly out (low level ink) or printer need service. Check it. using SSC utilty to resolve. Reset protection counter and clear counter overflow.
Jun 27, 2009 | Epson Stylus C46 InkJet Printer
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Flashing red/green lights
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. If you want to have a go at this yourself, the service manual can be downloaded from
http://www.mediafire.com/?m6ouftizois
Please report back if you need further help
Jan 24, 2009 | Epson Stylus Photo 810 InkJet Printer
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
