Question about Bose 901 VI Main / Stereo Speaker
What would be the correct placement of the Bose 901 series VI?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
This fully depends on the room.
If it is a simple square room, set the front speakers left and right about 2 meters from your TV, try to do the same at the back.
Point them slightly into your direction and try if this sounds good for you. If not you could try to turn them.
Posted on Nov 12, 2014
dunnbiker
  • 8546 Answers
SOURCE: Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Posted on Apr 13, 2009
SOURCE: bose 901 equalizer hookup
I had the same problem- I have a Pioneer VSX-518 and Bose 901 series IV. My receiver has no "Tape Monitor", so after trying different hook ups, I went and bought a "3 input video switcher" (about $10.00) I run my STB (cable box), my PS3 and my computer through the inputs of the switcher (just the audio L/R) then the output to the Bose EQ input, then from the Bose EQ output to my receiver input (I chose to use the TV/DVR input). Now I just have to select which source I want to listen to from the switch, make sure the receiver is set to TV/DVR and I have fantastic sound via my Bose 901s. With this hookup, I have my 3 componets video connected to my HDTV via HDMI cable. It works for me. Hope this helps.
Posted on Jun 25, 2009
  • 7 Answers
SOURCE: Impedance on my Bose 901 Series VI
there 12.9 ohms. there bose speakers not a wallmart if you want a lower impendance then run them in parralell brigde of a bridgeable amplifer/receiver
Posted on Nov 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a set of 901 IV with no equializer, I am
It will work, but theoretically less than 100% optimally as far as frequency balance; it would be a whole lot better than not having one at all.
Now, if you're contemplating using 901's in a multichannel environment, you have but to ask and I can provide that solution, too. Clue: you'll need a separate 2-channel amp for the 901's.
Posted on Mar 18, 2010
agent91
  • 2100 Answers
As far as I know, any equalizer will work. There is a guy on here that might know more about them, but I never had the Bose equalizer and I have Bose speakers for 35 years. The guy at the electronic store back then sold us a little equalizer at first, we graduated from that a long time ago, and now on the 3rd or 4th one. No problem, works great, sounds better than ever. Hope this helps.
Posted on Jun 27, 2010
What is a good placement for the 901 series VI speakers? I've heard the backwall is half the distance to the sidewall
Depends on the shape and contents of the room. Look up "best acoustic placement of speakers" in your web browser. Good Luck!
Nov 14, 2014 | Bose 901 VI Main / Stereo Speaker
Harmon kardon avr 146 with Bose 901 EQ VI
Bose is a pain in the back like Apple. Everything they make is proprietary or it won\'t work. The 901 series is one of them.
Nov 22, 2013 | Bose Audio Players & Recorders
Not sure of how to wire these speakers ( internal ) Bose 901 series iv
Found on Google Search: "bose 901 internal wiring" You must first identify which series you have. The first two series were acoustic suspension, and used nine 8 ohm drivers in a series/paralel configuration. Series III through VI used nine .9 ohm drivers all wired in series. Series III and IV had an additional terminal for use only with the Bose Spacial Control Receiver. Series III through VI are easy to identify, as there are three ports sticking out the back of each enclose. The 1st two series have no ports.
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
What is the best locxation for 901 series v1
Optimal placement of these like speakers of any design will vary depending on room dimensions and your listening distance from them.
A good place to start with them would be the same distance apart from each speaker as they are from the listening position. In that position they should also be placed closer to a rear wall than any side wall, approximately half that distance.
Dec 10, 2010 | Bose 901 VI Main / Stereo Speaker
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
How can i hook up my 30gb Ipod to my Bose 901 series VI and i have it hooked uo t couple of yahamhas
There has to be some amplification in here somewhere. Any single amplifier will not work correctly with the Active EQ for 901's applied to non-901 speakers.
Any MP3-player device with at least a headphone output can feed any standard audio device that has a Line Level input (other than "PHONO") once the output is adapted to fit the input.
Apr 25, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
170 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
