I have a sanyo Dp32648 it powers on but after about 30 seconds I lose picture the sound continues to work as does the power but I have no picture what could be the malfunction
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Nov 12, 2014
SOURCE: losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Posted on Aug 12, 2007
  • 92 Answers
SOURCE: westinghouse 30" lcd tv has no sound no picture,but green lighton
Replace the Power Supply.
Posted on Sep 06, 2009
SOURCE: KDF E60A20 screen goes blank loses sound for 10 60 seconds
I've had this same problem ongoing for a couple weeks. Finally, tonight it would shut off every 20-30 seconds, stay off for another 20-30 seconds then come back on. It turned out to be my bulb. I blew the TV out with compressed air, removed the bulb and disassembled it. Taking the bulb out of the plastic cage I then remove one of the metal screens at the top of the bulb, it just has little clips holding it in. I took a bottle of rubbing alcohol, some Q-tips and proceeded to clean the inside of the bulb through the screen hole. After cleaning the inside I put the screen back in, cleaned the outside of the bulb with a rag and alcohol, then reassembled everything. The TV is much brighter, I had to turn down the brightness setting and has been running the last few hours without an issue. You can avoid all this by buying a new bulb but I don't have the money right now to replace it and I'm cheap so I'll milk this bulb for everything it has. Heat kills bulbs so if you clean the screens and blow out the TV once every couple months you'll get a lot of life out of it..... I'm almost to 4 years on my original bulb and my TV is on constantly!! Good luck to all!!
Posted on Oct 05, 2009
milkburp
  • 416 Answers
SOURCE: I lose my picture it
You need a lamp. This is a common symptom. I hope this helps. I have a tutorial on the function and failure of lamps, check it out if you like. It explains why your TV is doing this. I hope this was helpful.
Posted on Apr 13, 2010
  • 8457 Answers
SOURCE: last night watching tv, picture cut off (black
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 10, 2010
When I turn the power on my Sanyo DP32648 the picture goes on for a few seconds then the screen turns black but there's still sound.What's wrong with it.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Apr 11, 2016 | Sanyo Televison & Video
Sound works great, has no picture
Did you look at power supply board for any puffed up caps on the power supply board?
the tops should be perfectly flat!
Apr 04, 2012 | Sanyo DP32648 32 in. LCD TV
Sanyo DP32648 I have sound and backlight but no picture. Is this most likely the Main video board or could it still be the power supply? I tried sending signal from computer at all resolutions to no...
I should say, it's either the inverter cable needs to be re-seated/replaced or the LCD screen needs replacement.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Aug 21, 2011 | Sanyo DP32648 32 in. LCD TV
TV powers on but there is no picture
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!
May 27, 2011 | Sanyo DP32648 32 in. LCD TV
My Sanyo DP32648 was plugged into a surge suppressor and during a lightning storm the TV turned off. The DVD player, stereo and the clock are all working fine, and were still plugged into the same surge...
If you look at the power supply board as shown in the picture: http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sjdps153ap1a.jpg
There is a main fuse on the top left of the board covered by black shrink tubing, SLO-BLO 4A 250V. Check it out to see if it is blown.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 27, 2010 | Sanyo DP32648 32 in. LCD TV
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Tv worked well last night...turned on this am.. sound but no picture
beachbabyfou, Use Sanyo warranty first, if covered. If not , then you or a electronics technician will need to troubleshoot and repair the unit's "switch-mode-power-supply" board. Partial power supply failure and unit can't "light-up" the cold cathode fluorescent lamps anymore. Is unit CCFL or plasma? If CCFL then possible same type problem as computer ccfl back-lit lcd monitors. Read some of the stuff in my fixya profile (older, higher pages) for more info. How old is unit? What is DOM? post back info you find. Yes, it could be failed capacitors on printed circuit board. Only rate this response if it helps you. 12fixlouie
Apr 05, 2010 | Sanyo DP32648 32 in. LCD TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
