Question about Samsung Televison & Video
After working fine for 10 minutes picture starts shifting horizontally and then it looses sync. I can only see flickering after that.
    Sergeant:
  • 295 Answers
Some component is drifting after it gets warmed up. This would take a qualified technician to resolve this issue. If the TV is still under the 1 year warranty they would fix it for free!
Posted on Nov 13, 2014
snakehead
  • 1074 Answers
SOURCE: intermintent picture
Check the horizontal output transistor this could be damage and causing the problem.another thing is pilot light that cause the screen to light up.since this is a projection t.v.it does not garry a tube.
Posted on Jan 22, 2007
SOURCE: Flickering and Jumping Picture
i have the same problem?
Posted on Mar 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: VS-45607
sounds like a defective cappacitor or leaky diode in the deflection circuits. Unless youre comfortable working around the high voltage circuits of a rear projection set, it may be best to call a reputable repair facility that is famillair with mitsubishi products.
Posted on Jun 15, 2008
SOURCE: RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Posted on Apr 21, 2009
NJ Logan
  • 31 Answers
SOURCE: horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Posted on Aug 27, 2009
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
I have this horizontal flickering problem on my philips 191EI.. Anyone know how to fix it? Thanks
This is not horizontal flickering. The picture is out of synchronization. The problem should be with its sync; separator stage circuit. For most modern TVs, this section will be a part of and IC, and is not repairable. Check what number IC is used as system-chorma-video jungle. It is faulty. Replace it. Before replacing, check all the components connected external to it. For details. You're seeing an out of sync: picture on screen. In this case, audio will be almost OK.
Nov 25, 2013 | Televison & Video
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
My 31GT740 tv's picture is taking up to 5 minutes to come on...
There is possibly a loose solder joint in the horizontal drive circuit. There is a little coupling coil just before the horizontal output that will get loose. This should not be real expensive to have repaired.
Oct 20, 2009 | GE 31GT740 31" TV
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
Jun 02, 2009 | Toshiba 32A33 32" TV
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Televison & Video Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
