My onida ctv no sond pictur is ok - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Nov 12, 2014
4 Suggested Answers
gopakumarg43
  • 74459 Answers
SOURCE: onida 21''ctv picture coming in stamp type
Hello
Replace its Horizontal output Transistor. If the base-emitter junction has a leak inside it, this type of fault will occur. Before replacing it, check the main DC voltage to LOT [Line Output Transformer]. It should come around 102VDC. If there is not this much voltage, check the electrolytic filter capacitor connected across thie supply line to main negative for open or value developed. Replace the same is good. Till there is low voltage found, check the retifier diode that rectifies this 102 volt DC. If all the above are OK and still you get a stamp like raster, check the heat of the Horizontal Output Transistor described above. if it overheats, LOT is defective and should be replaced with same type and number. OK.
Posted on Jun 12, 2011
gopakumarg43
  • 74459 Answers
SOURCE: onida 300 slim ctv service data wanted
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 730 posts to different brand TVs now.
Posted on Sep 11, 2012
SOURCE: sir,
2499 Horizentol tr over hit 25min abars sort
Posted on Aug 12, 2013
Onida CTV using str f6654 excess volt why?
Check all the related components at the power regulator circuit; after de-solder out the STR from circuit. If all are found OK, the STR is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the phrase " My service table today " in the search box of the display window [at the top right]. You'll get related posts gathered for reference.
Jul 23, 2015 | Televison & Video
Onida ctv no sound pictur is ok
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 12, 2014 | Televison & Video
How to get display in onida oxygen 250 ctv
Aug 26, 2014 | Televison & Video
My 20"onida ctv candy model set on but 5to7minnet after sound ok but vertically picture jumping or fillaraking please help me technically
Vertical rolling is the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 27, 2013 | Televison & Video
Onida ctv standby, r923 resistans is open so i want the resistants value
Try to read the color code of your resistor, if the resistor was burnt you have to do is send your TV to tech.
Dec 10, 2012 | Televison & Video
Onida 21''ctv picture coming in stamp type {cutting from four sides}
Hello
Jun 12, 2011 | JVC Televison & Video
Sir, my onida 20xs ctv make high boost transister 2499 has burnt
MOST OF THE 2499 TR IS DUPLICATE .SO YOU USE ONLY OLD TR.WHICVH IS TAKEN FROM OLD CTV BOARD. OTHERWISE YOU CAN USE 25INCH CTV H OUTPUT TR.
Aug 03, 2010 | Televison & Video
Onida Audioport 21'' CTV no picture & sound
this is video section problum .pls check video mute trangester is sort.
or croma ic is filed
Oct 20, 2009 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
