Question about Dryers
How do I properly hook up the metal tubing to vent my dryer?
Ten years ago my dryer was hooked up by the Sears delivery man. Today I noticed that the flexible metal tubing that goes from the dryer to the floor opening had a hole in it. I pulled the dryer away from the wall and removed the bad tubing. There were no clamps used to attach the tubing to the dryer or the floor opening. Just some duct tape. Also, there was a metal elbow type thing that was "attached" to the hole coming out of the dryer. It was also duct taped in place. The actual hole in the back of the dryer doesn't stick out enough th attach the flexible metal hose to it with a clamp. The elbow piece slides onto it, but is a loose fit. How do I keep the metal elbow in place so it doesn't pull out? Thank you.
    Genius:
  • 2,500 Answers
-There are many way to connect it. You can use
big hose clamp about 5" Diameter, or connect together then use 2 screws and then use duck tape over to seal any gap.
Good Luck
Mai Lor
Posted on Nov 14, 2014
4 Suggested Answers
  • 29 Answers
SOURCE: HI, The exhaust vent in
If your using a soft hose, go down and buy a corrugated aluminum hose. While you are there check to see if they have any metal tie wraps. However the heaver hose may do the trick. Also check to ensure that there is not any restrictions where you are discharging the air to. Let me know how it goes. :?) DRRXR
Posted on Feb 02, 2009
heatman101
  • 43501 Answers
SOURCE: Hi,
Often it is easier to install a metal vent pipe "ELL" onto that stub. You can usually get a drill in there with a sheet metal screw or two to hold the ell in place. Then you can easily hook the hose to the metal and get a zip tie around it. If you don't have an ell a larger zip tie will work if done arefully. You will need to loop and start the zip tie and place it over the hose before you slide it over the stub. Then slide the zip over the hose and use a needle nose pliers to pull the zip tie tight. A sheet metal screw behind the zip tie will help to secure it in place.
This should help you to solve your problem, be patient, the working conditions are tight and tedious, getting frustrated will only amke things worse for you.. I know I've been there!! :-)
Thanks for using Fixya!!
Heatman101
Posted on Nov 23, 2009
  • 2468 Answers
SOURCE: I was trying to remove
you will need to remove the top and front cover to be able to replace into the blower housing vent inside the dryer unit
Posted on Oct 14, 2010
Start up procedure
Check your vent duct, it may got clog inside there. Take off your vent duck from the rear of the dryer. Turn on the dryer again, if it is hot, your vent duct is the issue. Else, you need service man to take care of it.
Oct 07, 2013 | LG Dryers
Old dryer turns but does not heat, so bought a new one the same thing happens, can it be the electric plug?
A plug is easy to change, You can do it your self, Just make shure you turn your breaker off, Before you remove the old plug,Follow the wires on the old plug, End connect them to the same terminals on the new plug.Allso you can Write it down where they go,Before you disconect the wires from the old plug, Try the cheap route first, End that is to replace the old plug,
Oct 18, 2012 | GE GTDP490EDWS 7.0 cu. ft. duradrum...
Speed queen dryer takes twice as long to dry the clothes LGS27AWM3080 1003002387
disconnect vent tube and run a load of clothes, as it sounds like the vent tube is restricted. if that does not help then you will need to clean the dryer from the lint screen to the back of the dryers vent, where you hook up the vent tube. Hope this helped Tim
May 24, 2011 | Speed Queen AES17AWF Electric Dryer
How to install???????
ok. if it is a electric dryer u need a 220 volt plug in to make it heat and work. u need a dryer vent metal tube so the hot air and lent can go out. u hook up the vent tube plug in the 220 cord and it should be find. ok
Feb 13, 2011 | Dryers
Black soot causing whites to be gray
I too have the same problem with my Admiral dryer. Have come to the conclusion that the soot is making all my clothes greyer, but just noticed it with my whites. Took apart my dryer today and first of all found that the outlet below the lint vent was plugged. There is no soot on the outside of the drum or the dryer housing...however there is soot within the metal tube that surrounds the gas burner. Seems the gas is not being burned properly or the plugged lint trap was not letting the burned gases escape??? Laura
Jul 17, 2010 | Maytag PYG2300A Gas Dryer
HI, The exhaust vent in the back of the dryer is too short to clamp or tape the venting to. We cannot get it to stay hooked up. Any ideas on how to lengthen this? Do we need to remove the back of the dryer...
Feb 02, 2009 | Dryers
Front load dryer
Read the instruction manual carefully. If you are certain it isn't working as it should then don't hesitate and tell the supplier it is faulty and to send a replacement or give a refund.
Sep 24, 2017 | Kenmore 94802 Front Load Stacked Washer /...
I have a lg dryer model dlg2532w gas dryer it does get warm
if the cloths are warm and wet the problem is not with the dryer but in the venting. check the air flow at the end of the line (where the exhaust leaves the building) if the air baffels are not fully opening when the drier is on there is probably an issue with the venting. remember to tape up the venting joints after inspecting it because it is also the exhaust for the gas. hope this helps.
Sep 25, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
